clutch question ?
Old Feb 17, 2002 | 05:05 PM
11secdx's Avatar
Default clutch question ?
i installed a CM stage 4 clutch on a b20z motor, with a gsr tranny. i got the flywheel resurfaced, installed new throw out bearing, and new pilot bearing. it engages great through all the gears, but it kind of shakes the front end, when you start off in first, or in reverse. does anyone know what this might be? is it possibe to install the clutch disc backwards? please help
Old Feb 17, 2002 | 05:59 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: clutch question ? (11secdx)
Stage 4 is a non-sprung hub, right? You know, solid disc, no springs?
If so, the the clutch will chatter and shake the front end because it doesn't have the springs to help smooth out the engagement and disengagement of the clutch. Get used to it, because it won't get better.
Also, try not to end up next to a cop at a redlight because it might be hard not to bark the tires as you ease off the clutch
Old Feb 17, 2002 | 06:09 PM
11secdx's Avatar
Default Re: clutch question ? (B18C5-EH2)
thats the stage 5, stage 4 has springs, its a 4 puck style.i've put the same clutch in another car, but i can't remember if it acted like this or not.
Old Feb 17, 2002 | 06:13 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Okay, well even a 4 puck with springs will have a on-off type feel to it. Even the six puck sprung hub clutch in my car has a bit of a on-off feel to it.
Old Feb 17, 2002 | 06:43 PM
#417R's Avatar
I was thinking about getting the stage 4 for my b20. Will it ease up after it breaks in or will there always be the on/off?
Old Feb 18, 2002 | 01:40 PM
11secdx's Avatar
tt
Old Feb 18, 2002 | 01:43 PM
WAFFLES's Avatar
I believe that's typical for a Stage 4. My stage 3 is pretty jerky too.
Old Feb 18, 2002 | 03:13 PM
bruthaboost's Avatar
I have a clutchnet 6 puc with the extreme pp and I sometimes get clutch chatter when I reverse. I gotta throw the revs up and really slip the clutch to avoid the chatter. At first it seemed like on/off, but after 1000mi I can drive it like stock. You'll get used to it.
Old Feb 19, 2002 | 05:11 PM
11secdx's Avatar
i just realized that it does not have a front tranny mount. do you all think this could be the culprit to the shaking problem?
Old Feb 20, 2002 | 04:42 PM
MugenGTR's Avatar
it's pretty natural i think, i have the same clutch and it does the same thing. btw, do break in your clutch!!!!!!! i didn't and now my tranny doesn't work! all the syncho's are GONE!
BrianB16A2
Nov 3, 2013 07:20 PM
LU!SKEY
Aug 19, 2010 10:23 AM
Mr.Luder
Sep 18, 2007 02:20 PM
jdmlude_dude
Feb 27, 2006 07:28 PM
