clutch pedal
Just recently ive been having a little problem wiht my clutch. when i push in the clutch pedal to disengage the clutch, it travels all the way to the floor before doing so. I checked the fluid level, and it was empty. So i went ahead and added some fluid. I didnt have a chance to bleed the system, because i was by myself, and had to go to work. the acutal clutch seems to work fine, its just the pedal thats giving me a little troube. Any help would eb appreciated. this is for a 93 dx hatch.
thanx,
chazz
thanx,
chazz
Check the line for leaks, if you find nothing it may be the clutch master cylinder leaking under your dash.... When you get a chance bleed the line and check.. Hopefully everything is cool.. Latez
