Civic swap
Old Feb 12, 2024 | 03:10 PM
Hkineston057's Avatar
Default Civic swap
I got a 2000 civic I just put a d16y7 in it. It’s got a harness from a 1997 civic with a 37820-p2n-a22 computer in it. I can’t get any power to the fuel pump. I was wondering what pins I have to swap in the ecu
Old Feb 12, 2024 | 09:40 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Civic swap
That doesn't work... and the solution has been covered like over a thousand times... for God sakes, search man !!! Here is some spoon-feeding to get you started: You MUST use a '99-00 engine harness and the corresponding parts to work with it (distributor, CKF, knock, etc.). You will also need a '99-00 ECU or an OBD-2B -> OBD-2A conversion harness with the current ECU.
sibiryak70rus
Honda Civic (2001 - 2005)
Dec 23, 2015 09:11 PM
Alex_floresruiz
Nov 12, 2015 06:20 AM
'88civic
Jan 22, 2003 02:45 PM
Java110
Jun 23, 2002 10:06 PM
