chipped p28 ECU????
ok... wat settings for a Ls/vtec motor do i need to put on fo a p28 ECU?? Does any chipped p28 ECU work for an Ls/Vtec motor.. or does it have to be specifically for a DOHC vtec??? My friend has a chipped p28 for his civic, will that work for my 94 integra Ls/Vtec?? please help thanx http://images.zeroforum.com/smile/emsmile.gif
Re: chipped p28 ECU???? (cHinKrAcEr)
You will want a P28 Chipped for a DOHC engine. You will probably want a P30 or P72 program.
Re: chipped p28 ECU???? (HXMan)
cool thanx man http://images.zeroforum.com/smile/emthup.gif
i have a JDM P08 small case ECU thats re-chiped to DOHC VTEC with a Mugen program 5700rpm vtec, 8800 rpm rev limit, works on all OBDI b-series very well...
$200 shipped....let me know |
Re: chipped p28 ECU???? (eg6ajk)
I had my p28 for my ls/vtec chipped by locash. he put a dohc mugen program on it. but i had the rev limiter put at 8k because my bottom end isn't fully built with a block girdle and piston squirters. i just didn't want to be tempted to rev the crap out of it.
[Modified by WAFFLES, 11:29 AM 9/28/2001] |
...yes if you have a bone stock P28 ECU, it needs to be reprogrammed/chipped with some kind of DOHC VTEC program....specifically a Mugen program.
Usually, the Mugen program that is placed on a P28 ECU are of these specs: 5700 vtec crossover and has one of these rev limiters.. 8800, 9200, 9500, or no revlimiter. yes this program works well for LS/vtec or even B20/vtec engine setups.. |
Re: chipped p28 ECU???? (Katman)
aye WAFFLES , what have u got done to your ls/vtec and wats ur setup?? let me kno.. i wanna see what i need to do for my ls/vtec as well. thanx again http://images.zeroforum.com/smile/emthup.gif , O a chipped p28 ecu does not look for a Knock Sensor right?? cuz that's what i need it to do as well.. damn CEL comes on http://images.zeroforum.com/smile/mad.gif
[Modified by *****rAcEr, 1:19 AM 9/29/2001] |
I've got a PYR p28 ecu chipped to "p30+" specs. Bumped fuel and timing curves is what they told me. Worked great on my ls/vtec. Let me know if you want it-I can ship it to you. jgale00@hotmail.com
