Car wont start?!?
Old Feb 12, 2004 | 05:32 PM
JToolz's Avatar
Default Car wont start?!?
Ok I just put a 2000 Si engine into a 96 hatch and it started perfectly. The battery was really weak and just changed it and now it wont start. I put a new positive battery cable on it and it still is dead. All the lights come on in the dash so I know it isnt the igniton switch. Any ideas? I need help badly. It just doesnt make sense that it started perfectly on the weak battery and now I swapped it out and the motor wont even turn over. HELP?!?
Old Feb 12, 2004 | 06:22 PM
doublejz's Avatar
Default Re: Car wont start?!? (JToolz)
double check your grounds, throw a battery charger on just to make sure its charged. It doesn't take much to light up your dash
Old Feb 12, 2004 | 08:15 PM
JToolz's Avatar
Default Re: Car wont start?!? (doublejz)
I checked my grounds and they seem ok. The car did start with no problems before. The car wont turn over even with a jumpstart.
Old Feb 12, 2004 | 09:29 PM
Fobtions's Avatar
first of all u didnt mention if the starter is even cranking the engine, do u hear it??? if not its most likely the wires goin to that.
if its not cranking check for spark. need more info man
Old Feb 12, 2004 | 09:39 PM
JToolz's Avatar
Default Re: Car wont start?!? (Fobtions)
its not cranking at all. I turn key and nothing happens. All my dash lights work just perfect, headlights everything it just wont turn over anymore. Weird thing is that it turned over just fine before I changed the battery and now it wont start on new battery. It wont turn over at all, no clicks, starter doesnt engage.
Old Feb 12, 2004 | 09:52 PM
Fobtions's Avatar
try removing the starter than installing it again. its happened to me before.
Old Feb 13, 2004 | 09:38 AM
JToolz's Avatar
Ok I tried that but still no go.
Old Feb 13, 2004 | 04:57 PM
JToolz's Avatar
Anyone have any ideas?
Old Feb 14, 2004 | 11:49 AM
JSPECEX's Avatar
it is a fuse or relay in the ignition circuit happened to me and a friend becuase i was stupid and never disconnect the battery during radio installs. just bypass everything and us a jumper wire off of the ignition wire under the steering colum if it starts it the iginition if not check back i may have other ideas but prety sure that is what it is
multi_2009
Jul 31, 2017 12:18 PM
Eg Fool
19
Sep 12, 2009 07:28 PM
TheOdd001
Jun 26, 2008 08:19 PM
See Are X
Sep 18, 2002 07:48 PM
Lo-Buck EF
Aug 24, 2002 04:38 PM
