Can someone IDENTIFY this Distributor?
Old Aug 4, 2002 | 06:20 PM
SIINSI's Avatar
Default Can someone IDENTIFY this Distributor?
What cap & rotor do I need??
My engine is 96-97 spec JDM ITR. I tried ordering a newer ITR cap and rotor and it didn't fit. What cap and rotor do I need to order?
Thanks!!
Miguel
Old Aug 4, 2002 | 07:27 PM
HXMan's Avatar
Default Re: Can someone IDENTIFY this Distributor? (SIINSI)
Did you order the right type. I know most all hondas come with either Tec or Hitachi(sp?) Distributors...and the caps and rotors are different.
Old Aug 4, 2002 | 07:34 PM
JDM EG2's Avatar
Default Re: Can someone IDENTIFY this Distributor? (HXMan)
It looks like an obd2 distributor because it has a single plug. Do the wires look cut and spliced back together for the distributor?
Old Aug 4, 2002 | 07:41 PM
SIINSI's Avatar
Default Re: Can someone IDENTIFY this Distributor? (h22eg)
They don't look cut at all. It is a TEC distributor but, I bought a cap and rotor for a 2001 ITR. Maybe that was the problem... are 97 ITR distributors different from 2001?
Mike K. mentioned something about the older jdm motors possibly using LS cap/rotors, can anyone verify this?
Thanks for the help...
Miguel
Old Aug 5, 2002 | 12:17 PM
SIINSI's Avatar
Up
Miguel
Old Aug 6, 2002 | 09:30 AM
SIINSI's Avatar
One last try
Miguel
Old Aug 6, 2002 | 10:22 AM
TedR719's Avatar
Try a 97 ITR. I'm looking at my cap right now and it is identical to what you have in the pic. It's says Tec on the cap as well. I just bought a brand new cap/rotor from Acura for an ITR but yet to put it on my car.
Here is the numbers on my box if that will help to identify it.
Cap - 30102-P72-006
Rotor - 30103-P73-003
Old Aug 6, 2002 | 12:16 PM
X2BOARD's Avatar
Default Re: Can someone IDENTIFY this Distributor? (futuresi)
Looks eeriely like my older 97 LS's cap... obd2. B16 cap would also do the trick too.
Old Aug 6, 2002 | 10:43 PM
SIINSI's Avatar
Default Re: Can someone IDENTIFY this Distributor? (X2BOARD)
Thanks fellas!!!
Miguel
carblegal
Oct 26, 2006 03:28 PM
garyc17
Jun 2, 2006 01:31 PM
Mike95lude
Oct 27, 2003 01:02 PM
SIINSI
Aug 5, 2002 09:33 PM
