cams for a b20
Old Aug 23, 2002 | 05:45 PM
ef ect's Avatar
Default cams for a b20
looking for cams that will go in to my usdm b20b and hopfully help keep the torque for a few hundred more rpms anybody with experince? what works, whats best for dayly driving. i have herd that ls cams will go in anybody with experince with this or has anybody put in stock ls cams in a b20 or perhapse b20z(jdm b) cams in and seen any gains. Just woundering if anybody has done this. Or has any body had luck with cam gears on these moters. changing timing belt on moter while on stand and thought i might do somthing while i got it apart aslong as i will help some any imput is great ....
Old Aug 23, 2002 | 06:24 PM
bloobin's Avatar
Default Re: cams for a b20 (ef ect)
i hurd b20 cams are every sooo slightly more aggressive than the ls b18b ones. If you not getting crowers, i'd save the time and money and just try to get the whole setup to flow better.. (homemade dryer duct intake.. maybe a nice header and str8tpipe.. )
just my .02
Old Aug 23, 2002 | 10:41 PM
JalopySiR's Avatar
I have some aggressive cams in my B20. IMO, this is not needed until you have a minimum of a good intake, Skunk2 IM, Headers, a high flow cat, and exhaust. I have the intake... If I could do it over I would wait on the cams. They made power, but they are SEVERLY hindered by the 90-91 LS intake and exhaust manifolds I am currently using. The 160k mile cat isn't helping either. If you wish to disregard this advice please contact "Rocket" on this board. Tell him JalopySiR sent you. He is a great guy, and will give you some pointers. Try searching as well...there is a good archived topic about this...
Old Aug 27, 2002 | 06:14 PM
StorminMatt's Avatar
Default Re: cams for a b20 (JalopySiR)
You are using a 1990-1991 intake manifold on a B20? OUCH! Are you aware that the port size is alot larger on the B20 than the 1990-1991 Integra? Alot of people out there are losing TONS of power because they are using this manifold. Do yourself a favor and at least get a stock 1994-1995 B18B manifold. It has ports of the proper size. Or get the Skunk2.
Old Aug 27, 2002 | 09:11 PM
JalopySiR's Avatar
Default Re: cams for a b20 (StorminMatt)
I told you this a long while ago. The skunk2 is in my closet till after dyno day.
Old Aug 28, 2002 | 05:39 AM
DevinW's Avatar
It'll be interesting to see what difference the skunk2 IM makes over the older LS IM....don't forget to post your dyno charts JalopySir
slo_hatch
Oct 22, 2008 10:21 PM
GoCarInteg
Sep 7, 2005 02:37 PM
silver_nteg
Mar 30, 2004 09:02 PM
kinvid22
Jan 10, 2004 12:02 PM
Shua derson
May 13, 2003 11:20 PM
