cable trans + cable cluster -> P28?
Old Oct 11, 2009 | 09:49 PM
night's Avatar
Default cable trans + cable cluster -> P28?
ok i rarely post a question but i've been searching for 30 min on here, g2ic, and google and have not found a definitive answer yet.
the title pretty much covers it. with cable trans and 92-93 cluster it seems like a no brainer to then run the vss signal to the P28 from the cluster as is stock on the DA.
the question though.. are pulse signals the same?
even checking alldata i see the DA specifies 4 pulses per revolution while the P28 says 4000 per mile. completely useless info by itself.
i am only making a big deal about this now because the engine will be towed 30 miles to the tuner for 1st start and break in on the dyno. i'd really rather not get there and have something i guessed at not work.
(also, i realize the tuning software can turn it off as a vtec check, but i'd rather not if possible)
Old Oct 12, 2009 | 08:04 AM
88Hatchy's Avatar
Default Re: cable trans + cable cluster -> P28?
It should work fine.
Old Oct 12, 2009 | 09:29 AM
night's Avatar
ok, at least someone said it. still looked even longer last night after posting this and nevre saw it specifically said.
just wanted to make sure i wont end up with the ecus data reading at half or double speed or something.
Old Oct 12, 2009 | 11:35 AM
Jaker's Avatar
The speed pulse generated by the cluster mounted speed sensor in the 1990-1992 Integra and the 1988-1991 Civic is identical to the pulse generated by the transmission mounted VSS in the 1994-2001 Integra and the 1992-2000 Civic: 4 pulses per revolution of the sensor.
Old Oct 12, 2009 | 07:22 PM
night's Avatar
ahhh.. good. thank you. exactly what i was digging for.
GabesEF909
Sep 24, 2012 09:16 AM
Gawear
Jun 19, 2010 08:22 AM
peanut butter
Feb 18, 2008 04:00 PM
JapJunkie
13
Feb 1, 2007 02:30 PM
coot_er
Oct 2, 2005 10:33 PM
