Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Hybrid / Engine Swaps (https://honda-tech.com/forums/hybrid-engine-swaps-18/)
-   -   bogging at full throttle (https://honda-tech.com/forums/hybrid-engine-swaps-18/bogging-full-throttle-589502/)
dpine Aug 11, 2003 04:58 PM
Just did a b16 swap in my brothers 90 civic dx a month ago. Heres the problem when I give the car full throttle it will bog real bad, but only at full throuttle throught out the rpm range. I can part throttle the car to redline. I thought I had a distributor problem because of a code 4 on the ecu. well I bought a rebuilt distributor from hybrid garage. well the code 4 went away but the bog didn't. I also have codes 10, 14 that I heve not gotton fixed yet. Any suggestions
thanks
VTECVillain Aug 12, 2003 04:39 AM
Re: bogging at full throttle (dpine)
Code 14 is the IAC (EACV) - Idle Air Control Valve. It's safe to say that it probably won't bog if you fix that..... https://honda-tech.com/forums/images/smilies/emwink.gif
dpine Aug 12, 2003 12:42 PM
Re: bogging at full throttle (VTECVillain)
I think I might be reading the codes wrong. here is what I get when I turn the key to the on position, I get one blink for the ecu then a pause then one long blink then a pause then one long blink and four short blinks
dpine Aug 13, 2003 05:31 PM
that was the problem, Idle Air Control Valve . we extended the wrong plug (whit plug) so I found the right plug (green plug with blu/ylw blk/ylw wires) reset the ecu and took it for a drive, problem fixed.
thanks a lot for you help.
poison Aug 13, 2003 05:42 PM
great to see its fixed. You said you had code 10?
Do you have any more codes?
dpine Aug 13, 2003 05:54 PM
Re: bogging at full throttle (poison)
I think I still have a code 10. when I turn the key to the 2 position I get a blink for the ecu then a pause and a long blink then a really long pause and then another long blink and then a really long pause over and over until I turn the key off. where is the air tem sensor located anyways and what color plug is it with what color wires?
thanks
poison Aug 13, 2003 06:15 PM
That would be the IAT. It's a white sensor on the intake manifold and is a 2 plug connector.
It has a Grn/Wht wire and a Red/Yel wire.
HTH.
dpine Aug 14, 2003 12:20 PM
is that plug on the factory DX harness? if not the plug has 2 wires one goes to a ground but where does the other wire go on the ecu?
thanks
poison Aug 14, 2003 01:35 PM
D15
dpine Aug 14, 2003 02:25 PM
yes d15
poison Aug 14, 2003 02:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpine &raquo;</TD></TR><TR><TD CLASS="quote">is that plug on the factory DX harness? if not the plug has 2 wires one goes to a ground but where does the other wire go on the ecu?
thanks</TD></TR></TABLE>
I'm saying D15 pinout lol
dpine Aug 15, 2003 04:29 AM
update: well last night I got the IAT code cleared. Now there is no check engine light and no codes. thanks alot to everyone who posted. now I can finally get a chance to work on my car. again thanks to all
