bigger rad in hybrids?
ok to my knowledge you should get a bigger or at least a more efficient radiator when you swap to a bigger engine. i've seen b18's, b16's and even h22's wit the same stock rad the civic chassis came wit and even some with turbo's. now isn't that a cause for concern or are those configurations ok?
please shed some light on this lil subject as i'm carefully planning my swap. thanks
A dual-core would be ideal but not nessasary.
Many people run with B-series swaps with the stock radiator with no problems. If your going H22 or you have A/C I would advise a upgrade but it's not required. Before you spend the money see how your car does with the stock one. I've run a year in Florida summer drive-thru's with a stock radiator, B16, and it's kept cool.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt »</TD></TR><TR><TD CLASS="quote">A dual-core would be ideal but not nessasary.
Many people run with B-series swaps with the stock radiator with no problems. If your going H22 or you have A/C I would advise a upgrade but it's not required. Before you spend the money see how your car does with the stock one. I've run a year in Florida summer drive-thru's with a stock radiator, B16, and it's kept cool.</TD></TR></TABLE>
Percisely. Some H22 swaps come out and run fine (no overheating) with just the stock single-core Civic radiators still in them. Some want to run hotter so we recommend changing out the radiator for a dual core or larger/GSR one and it solves their problem. Everyone has a different car so they're all going to work differently. Try your current setup... if it overheats or starts to run warmer than before, first try flushing your radiator fluid and checking your thermostat. If that doesn't change it, then upgrade to a "bigger" radiator.
Also a dual core radiator is not even that expensive I mean for a little under $200 I got a gsr radiator which is full length and dual core, so I mean I nots that much considering you do not want your motor you spent all those blood sweat and tears on to over heat.
when flushing my coolant, i went ahead and bought a new $120 gsr rad for my jdm b18c. just had to fab some brackets and wahlaa! looked a lot better with a full length rad, i couldnt see my 4-1 headers anymore.
later
later
thanks guys for the replies. thats what i thought too get the bigger rad and save myself some trouble or if i have any trouble at all.
well i'm goin with usdm b18c with nitrous probably end at 100 shot. are the delsol vtec dual cores better than the gsr ones or vice versa? or should i just get a brand new all aluminum one from fluidyne
or something?
thanks again
or something?thanks again
91efbluehatch
13
Jul 19, 2011 09:45 AM
Greasemonkey
31
Jan 5, 2005 07:10 AM
