b20z2 or b18b??
Old Jun 24, 2012 | 06:43 PM
eazy_209eg6's Avatar
Default b20z2 or b18b??
Okay so I have a '95 DX hatch and I plan on doing a swap soon. Right now I just have a stock d15 non vtec, but sitting on the side i have a b20z2. I've heard that the b20's and thinner cylinder walls and can't stand high RPM's and I want to do an all motor build non vtec. I was wondering if I should just go with a b18 or the b20??? help please. thanks.
Old Jun 24, 2012 | 07:01 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: b20z2 or b18b??
Why, please tell me why you need high rpm?? It won't give more power on either of those engines. The B20Z does NOT have thinner walls, and it is a very good engine, and makes a good chunk more power on the street!
Old Jun 24, 2012 | 07:10 PM
I know higher RPM's doesnt give me more power, but it makes my power last a little longer in my opinion. So you're saying that the b18 and b20 are just about the same??
Old Jun 24, 2012 | 07:45 PM
Deetz's Avatar
Crazy Honda Guy
Sorry, but power for longer? The B20Z makes power a LOT earlier, and continues right to redline at 6700rpm.....i would hardly call it a smaller power band. So what if you shift earlier, the power is waiting for you again in the next gear up
and no, the B18 is a fair bit weaker than the b20
Old Jun 24, 2012 | 08:04 PM
Now it makes sense! b20 has more torque. Now I get why it has lower RPM's. So to go back to the cylinder walls.. I've heard from a hand full of people that the b20 has thin cylinder walls, you seem pretty experienced so I just want to know your info about.
Old Jun 25, 2012 | 03:01 PM
Deetz's Avatar
Crazy Honda Guy
I used to run a 96 civic hatch with a 2000 model b20z...it was awesome, and made "way" more power than the b18b
Who ever told you the wall were tinner, has no idea what they are talking about The walls are simply mounted differently, but are NOT thinner...you must educate those talkers, lol
here's a pic of a B20Z shortblock
Old Jun 26, 2012 | 09:35 AM
Thanks for the info man. Did you do an all motor b20z?
Old Dec 26, 2020 | 04:03 AM
Matt Coley's Avatar
Ok to answer that I can only tell u what I know from experience. I have 97 hatch I did a bswap with B20Z2 and I have had no problems with running high rpms and I have had it running on a steady 7000 with no falter as far as the b18 goes I don't know hope this helps some
LIKEABO55
Honda CR-V & Element
Jan 16, 2013 07:30 AM
Truman001
Jan 7, 2008 09:28 AM
spoonef
Sep 1, 2005 11:23 AM
RotiEatter
30
Dec 19, 2002 08:59 PM
b18bvudoo
Jan 17, 2002 01:39 AM
