B20vtec or GSR????
Old Dec 14, 2004 | 01:24 AM
xAznRac3rx02's Avatar
Default B20vtec or GSR????
okay i currently own a GSR, but the engine has 125k miles on it. I wanna rebuild it cuz i want more power out of it. I AM not gonna track my car or take it dragging every week or anything. I just want to be able to have the torque when i want it
GOALS:
Hit at least 200whp
I want a good amount of torque (i dont have a real specific number)
I want to be able to rev to about 8,000K
I want a reliable engine
Spend less than $3500
I dont know that much about engines, but i have been researching on these forums, as well as team-integra and automotivetech.org. This guy that i've sorta been talkin to works at a shop, and he suggested two things for me:
EDIT
1. Keep B18C1 and resleeve block to 85mm, which would make my displacement pretty close to 2.0 (solves the torque goal). He also said he could do a 5 angle valve job. He said he would also build my bottom end w/ JE pistons (12:1 Compression) with Eagle Rods. Some other titanium stuff that i can't remember. He said he would port/polish my head, titanium Valve Springs and retainers. Bigger, more aggressive cams. The only problem with this is that its going to cost around $5000
EDIT:
2. Get B20 bottom end. JE Pistons 10.5 Compression. Eagle Rods. Balancing and Blueprinting Block. Titanium Retainers and Valve Springs. Port/Polish Head. Bore out my GSR Intake Manifold. Either a B16, GSR, or ITR head. Hondata Chipping and Tuning. He said it should be safe to rev to 8k. He said this set up would cost about $3500, maybe less. Any suggestions on a good B20 Set up???
What do you guys think? Should i keep my GSR engine, or get the B20? Is the b20 block reliable if i plan to rev it hihg? Suggestions? Comments? Any other set ups i should look into??
Modified by xAznRac3rx02 at 7:11 PM 12/16/2004
Old Dec 14, 2004 | 06:04 AM
The Specialist's Avatar
Default Re: B20vtec or GSR???? (xAznRac3rx02)
Go with B20 vtec bro, my B20 is at like 180hp with only ITR header, aem int., ctr cams, and exhaust. Now if you with pistons and some stage 3 cams with Vafc you'll be close to that 200hp. Just a suggestion.
Old Dec 14, 2004 | 06:40 AM
jerZeyReX's Avatar
keep the gsr a b20 is a grenade without getting the bottom end rebuilt and resleeved...the sleeves are paper thin...you can definitly get 200whp out of a gsr just stick with that motor and do the valvetrain and bolton's plus a vafc or hondata and you'll make 200 whp...id only mess with the b20vtec's if you got around 5 or 6 for a sick rebuild
Old Dec 14, 2004 | 07:55 AM
Beyond Imagination's Avatar
if you already have a b18c and are resleeving it why are you even thinking of a b20 block? your 85mm bore will have more displacement over the 84mm. not too sure on price but a rebuild consisting of high comp pistons, resleeve/bore, rods would be a start.
and FYI b20 sleeves are NOT paper thin
Old Dec 14, 2004 | 09:24 AM
HipHop Head's Avatar
Default Re: B20vtec or GSR???? (Beyond Imagination)
do b20vtec but make sure u build it right
Old Dec 14, 2004 | 10:39 AM
dohcdelsol93's Avatar
Default Re: B20vtec or GSR???? (Ej Oner)
put an ls crank in your gsr and have it re-sleeved or bored out depending on your budget. The longer stoke give you more torque lbut you have the stronger bottom end of the gsr and a thicker cyl. wall than a b20.
Old Dec 14, 2004 | 11:11 AM
Fate's Avatar
Default Re: B20vtec or GSR???? (dohcdelsol93)
get the b20. b20 = gawd of torque. build that bottom end up. hell if you are gona resleeve a motor resleeve the b20 and bore it out to a 2.2L
Old Dec 14, 2004 | 12:05 PM
Thanks for the advice... keep em coming guys
Old Dec 14, 2004 | 02:37 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: (xAznRac3rx02)
if you hve the $ resleeve the gsr to 84.5mm with aroung 11.5 CR that is the same setup that we (hookups/R&D) won the import tuner b series shootout with
Old Dec 14, 2004 | 09:34 PM
Default Re: B20vtec or GSR???? (EGRacersInc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGRacersInc &raquo;</TD></TR><TR><TD CLASS="quote">get the b20. b20 = gawd of torque. build that bottom end up. hell if you are gona resleeve a motor resleeve the b20 and bore it out to a 2.2L</TD></TR></TABLE>
Werd Madd torque
Old Dec 15, 2004 | 10:57 AM
jdmxxdc2's Avatar
Default Re: B20vtec or GSR???? (racer_x_eg)
ever thought about turbo on ur gsr?
Old Dec 15, 2004 | 11:22 AM
clint g's Avatar
Default Re: B20vtec or GSR???? (jdmxxdc2)
I would take hookups advice because it seems more sensible to me
Old Dec 15, 2004 | 02:33 PM
Default Re: (HOOKUPS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOOKUPS &raquo;</TD></TR><TR><TD CLASS="quote">if you hve the $ resleeve the gsr to 84.5mm with aroung 11.5 CR that is the same setup that we (hookups/R&D) won the import tuner b series shootout with </TD></TR></TABLE>
Yea, that was one of my options, the only thing is that it will cost me more than what i have.
Old Dec 16, 2004 | 05:06 AM
b18c1tcivic90's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmxxdc2 &raquo;</TD></TR><TR><TD CLASS="quote">ever thought about turbo on ur gsr?</TD></TR></TABLE>
turbo
$3000 for hyrbid kit
$600-1000 for FMU
run low boost and you'll be fine with the right tuning of course.
Old Dec 16, 2004 | 11:17 AM
Default Re: B20vtec or GSR???? (b18c1tcivic90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1tcivic90 &raquo;</TD></TR><TR><TD CLASS="quote">turbo
Yea TUrbo did cross my mind. But i wanna turbo, i would HAVE to get new parts for my engine so that it could handle the boost. The Engine is kind of old, and id ont think it would last long if i boosted my car. So not ONLY do i have to buy the turbo, but i have to pay for new pistons, valves, springs, etc
Old Dec 16, 2004 | 12:00 PM
hybridpatient95's Avatar
b20vtec baby
Old Dec 16, 2004 | 02:47 PM
Default Re: B20vtec or GSR???? (kinkbmx159)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kinkbmx159 &raquo;</TD></TR><TR><TD CLASS="quote">b20vtec baby</TD></TR></TABLE>
Old Dec 16, 2004 | 06:10 PM
Yea... the ppl that i've talked to have suggested this. They say it depends on what i want, But since i want torque and not high-revving, i think i'll end up doing teh B20
And O Yea!... i Edited my 1st Post w/ more Detail
Old Dec 16, 2004 | 09:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xAznRac3rx02 &raquo;</TD></TR><TR><TD CLASS="quote">
And O Yea!... i Edited my 1st Post w/ more Detail</TD></TR></TABLE>
Good choice buddy
Old Dec 17, 2004 | 10:58 AM
Bump
Old Dec 17, 2004 | 02:20 PM
very good choice you wont be disappointed cuz my friend has one. pulls hard
Old Dec 18, 2004 | 01:08 AM
slowpokecivic's Avatar
Default Re: (kinkbmx159)
nice choice...
sell your b18 to me...
Old Dec 18, 2004 | 03:02 PM
Default Re: (HoNdAxCiViCxGs-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HoNdAxCiViCxGs-R &raquo;</TD></TR><TR><TD CLASS="quote">nice choice...
sell your b18 to me... </TD></TR></TABLE>
I'm taking offers for my engine..
Old Dec 19, 2004 | 10:34 AM
PM me with price for your motor
Old Dec 19, 2004 | 03:58 PM
Default Re: (racer_x_eg)
crv vtec fo show maddd tq
