b20vtec 12:1 comp tech q's
Old Apr 2, 2002 | 01:42 PM
drifter's Avatar
Default b20vtec 12:1 comp tech q's
I have a couple questions. Could i run pump gas with 12:1 pisons(91 octane). I have a b16head 81mm b20 is 84mm should i get the combustion chamber *deshrouded(is that the right word?) to lower cr and resist detonation, and how much would that cost. Also with these pistons would i be able to switch over to ctr cams with out smashing the valves into the pistons
thanks in advance
Old Apr 2, 2002 | 07:04 PM
tinkerbell's Avatar
Default Re: b20vtec 12:1 comp tech q's (drifter)
good question,
also what pistions are you going to use?
Old Apr 3, 2002 | 04:46 PM
drifter's Avatar
Default Re: b20vtec 12:1 comp tech q's (tinkerbell)
jg 84.5 mm
THEhomelessONE
10
Apr 20, 2022 12:23 PM
typeR4u
11
Feb 25, 2015 06:31 AM
j spec
11
Jul 26, 2006 01:36 PM
ThatsMyEG
Jul 26, 2005 05:40 PM
drifter
Apr 3, 2002 04:53 PM
