b20b into 97integra... CPS sensor?
Old Oct 7, 2003 | 10:32 PM
2SLO's Avatar
Default b20b into 97integra... CPS sensor?
okay, i have a b20b in my 97 LS integra... the LS motor had a crank position sensor (or whatever its called that mounts to the oil pump) and the b20 dosent have one. is there holes to mount the sensor on the b20 oil pump or a way to get rid of the CEL? please help
Old Oct 7, 2003 | 10:46 PM
2SLO's Avatar
bump
Old Oct 8, 2003 | 05:22 AM
VTECVillain's Avatar
Default Re: b20b into 97integra... CPS sensor? (2SLO)
That is the Crank Fluctuation sensor. Since you are running the OBD2 ECU you will need to change the oil pump to an USDM OBD2 oil pump in order to mount the sensor, you could swap them over from your old motor.
Old Oct 8, 2003 | 08:55 PM
2SLO's Avatar
Default Re: b20b into 97integra... CPS sensor? (VTECVillain)
no other way to do it eh?
Old Oct 13, 2003 | 08:07 AM
2SLO's Avatar
bump?? cant put a resistor of some sort to trick the ecu?
Old Oct 13, 2003 | 08:35 AM
Default Re: (2SLO)
I would say that you could probably do this. I've never fooled with it myself though. I'll take a look at my Helm's when I get a chance and see what resistance it looks for.
potatointegra01
Feb 2, 2016 04:23 PM
existanzcivicb20
Mar 15, 2006 11:47 AM
warwagon
Jan 11, 2005 05:14 PM
MassScene
Dec 14, 2004 04:55 AM
boostin4drcivic
May 1, 2004 02:30 PM
