is a b20 worthy?
isa b20 a good motor?> wat i wanna do is put my b16 head on it , but if its not a good idea then i wont do this ill just get an LS? wat shall i do i cann get an b20 cheaper then i can geta LS so just want some input if u may
Don't build one if you want to rev the **** out of it. A B20VTEC is a great road racing motor because you get almost immediate torque response everywhere in the powerband. A B18B is probably more up your alley if you have to ask this question in the first place.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">A B18B is probably more up your alley if you have to ask this question in the first place.</TD></TR></TABLE>
get any b20 crv block if your gonna run the block sock look for a b20z because that has 9-5 compression instead of the 8-8 b20b..throw a b16 head since they flow better then a gsr stock but change the cams to maybe ctr or gsr.if you have the money install those new rs machine itr style pistons they came out with for the b20 block.youll make upto 200 whp easy with those pistons.
do the b20 vtec. i had a stock b20 block, stock gsr head and cams, blox intake manifold, dc header and made 180whp and 138tq. my **** was quick for a simple build. lasted me 10k miles before i pulled it out for a new set-up. i was reving to 8k
B20 is ****, go with a B18B, the 6 or 7 lbs or torque and some can be gained with mild head work intake, exhaust and retuning.
imo, the B18 is far more stout
Go ahead and use the B20. All motor the extra torque will help. If you were going to boost it, I 'd say B18 all day long. The sleeves are what makes the difference.
Anyone got a price for the ITR style b20 pistons?
Depends.. boost or no boost? If boost, b20 is expensive, as it needs to be sleeved and rebuilt. If yer heading all-motor, slap a vtec head on and yer set for a long time - with all the low end b20 benefits and the vtec high end. But the boost thing is serious.. if you're gonna go stock and boost, I read that beyond 6psi is a horrendous idea. So.. if boost desired, grab a b18a or b18b. The right people can find 'em in good shape for $50.
i did B20B4 v-tec with a built B16 RC310cc inceters. skuck2 stage 2 cams, skuck2 manifold, DC type-r header, ITR tranny, hondata.!! it made 200WHP all day 13.8 at a 102 mh. with a 2.3 60foot on shity tires and full interiour and 91 pump gas
latinf86
Jun 25, 2006 11:45 PM
