B20 swap specifics?
Old Feb 21, 2003 | 03:17 AM
Tiamat-blue's Avatar
Default B20 swap specifics?
I have a 99 civic DX and want to swap in a B20Z. Unfortunately it's my wifes car and an automatic. Ya...it needs to stay that way...
1. Does the CRV use a TCM like the integra? That would seem like a pain.
2. Being a civic based platform what mounts would I need? Specificly the transmission mounts.
3. Would the exhaust bolt up(with a new cat welded inline)?
I've done lotsa searches but can't seem to find too much related to either B20's or auto tranny swaps(go figure).
Thanks!
Old Feb 21, 2003 | 03:40 AM
Trey's Avatar
25 Year Member
Default Re: B20 swap specifics? (Tiamat-blue)
In terms of swaping, the B20 is no different than the B18a/b/c. Same mounts and wiring applies.
http://www.jspectuning.com/6gen
Old Feb 21, 2003 | 03:53 AM
Default Re: B20 swap specifics? (Trey)
But with the automatic tranny??
Old Feb 21, 2003 | 03:56 AM
Westrock2000's Avatar
Get an LS automatic tranny and keep it on the B20. Chances are the B20 will come with a flexplate already on there.
You can either use a AT LS ECU or possibly just your AT DX ECU.
It will be like doing a complete changeover, just the shiftlinkage part of the swap will differ.
I could have errors here, so other poeple can certainly voice their opionion
Old Feb 21, 2003 | 03:58 AM
Default Re: B20 swap specifics? (Westrock2000)
Understand that you will probabaly not be able to add a VTEC head to this.
Hmm, unless you used a Civic EX automatic ECU...the automatic EX's still had VTEC right?
Old Feb 21, 2003 | 04:03 AM
Ya the ex's had vtec, but I'm not too worried about that since the tranny usually shifts before vtec anyway... I did plan on using the at dx ecu, at least for a while. I just had concerns about that fact that the integra uses a seperate computer for the tranny. But thanks, that helps!
Old Feb 21, 2003 | 02:13 PM
GapxGuy's Avatar
Sushi Buffet Champion
Just use the Integra LS ecu and AT tranny.
nels00n
Feb 11, 2009 07:26 AM
eugene_fender
May 23, 2007 06:23 PM
danny_ha
Aug 28, 2006 07:59 PM
EF9_R_Killa
10
Jul 11, 2002 02:32 PM
civic dx
May 15, 2002 11:43 AM
