B20 questions
Old Jul 22, 2003 | 01:16 PM
FlatBrokeHatch's Avatar
Default B20 questions
how many different types of B20s are there?...
specs on each?
i heard that LS cams work very well in a B20...is that true?...
what axles used for a B20 into an EG?
use an LS ECU am i correct?
any help would be much appreciated.
Old Jul 22, 2003 | 03:43 PM
Silverhatch's Avatar
I have a friend thats running a b20 bottom end .ls computer with a built ls head. he dosent have a b20 head.I think there are b20b and a b20z.
Old Jul 22, 2003 | 04:21 PM
eg6ajk's Avatar
Default Re: B20 questions (FlatBrokeHatch)
there were basically 4 kinds of variation of the motor from 3 different intakes to two different pistons, cams used to mounts.
LS cams are weaker then some B20 cams or identical. no point of swapping these in unless of course they are aftermarket.
if you you are dropping the motor in the EG, then you need to run a hydro tranny such as Y21/S21/S80/Y80/S4C type with 92-01 Civic/Itegra b-series axles/intermideate shaft.
yes a 92-3 PR4 ECU or 94-5 74/P75 ECU
Old Jul 22, 2003 | 04:32 PM
b20_ed's Avatar
Default Re: B20 questions (eg6ajk)
darn it, I remember a long "all about b20s" thread somewheres?
Old Jul 22, 2003 | 05:07 PM
Lysawy's Avatar
Default Re: B20 questions (b20_EK)
search for b20 i got the following 83 results
Don't be lezy and search
Old Jul 24, 2003 | 09:11 AM
Default Re: B20 questions (Lysawy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lysawy &raquo;</TD></TR><TR><TD CLASS="quote">search for b20 i got the following 83 results
Don't be lezy and search</TD></TR></TABLE>
Congradulations
but i was looking for answers for my particular questions...so i didnt want to drudge through 83 topics and pick apart the answers that i need.
thanx for the help eg6ajk
DrGrEeNtHuMb
Feb 19, 2008 05:38 PM
sycamore
Aug 19, 2005 03:37 PM
93_civic_hatch
Jun 19, 2005 10:32 PM
ALLMOTA92EG
Feb 6, 2005 11:28 PM
