B20 question
Old Mar 6, 2006 | 06:58 PM
k4ff1n3's Avatar
Default B20 question
so my JDM ITR motor blew up and im thinking about using a B20b longblock in its place so i can still drive around...
my question is, will parts from my type r fit the b20.. ie intake manifold, header..etc..
thanks
Old Mar 6, 2006 | 07:43 PM
JDMFreak's Avatar
Default Re: B20 question (k4ff1n3)
your intake manifold will not...i am currenlty using B16 header, so i can say yes on your header as well...
are you going to use a straight b20? or slap vtec on it?
Old Mar 6, 2006 | 10:09 PM
k4ff1n3's Avatar
Default Re: B20 question (JDMFreak)
im just going to use the b20 as a "beater motor" till im donw building my R. im using this situation to do a FI build..
Old Mar 6, 2006 | 10:48 PM
Ruben19's Avatar
nothing will fit from the vtec series.
only b20 and b18b
Old Mar 10, 2006 | 03:28 AM
k4ff1n3's Avatar
Default Re: (Ruben19)
another question... what ecu are you b20 guys using? should i just use a p75? im already wired for obd1 . what year p75 is the obd 1 version?
Modified by k4ff1n3 at 8:10 AM 3/10/2006
Old Mar 11, 2006 | 06:03 AM
k4ff1n3's Avatar
Default Re: (k4ff1n3)
also heres what im working with at the moment..
99 crvmotor
99 si wire harness converted to obd1 (made to use on B18c-R)
everything else i currently have is for my R motor.. im getting a P75 from a friend.
im assuming everything will drop in and i wont have to do much at all.
please correct me if im wrong.
also ive been reading that the p75 runs lean as hell, if it starts up at all. what fuel management do you guys suggest. im assuming that i cant use my vafc.
Old Mar 12, 2006 | 02:11 PM
k4ff1n3's Avatar
anyone , any help at all?
another question. do LS head parts.. ie cams, springs fit the B20?
Modified by k4ff1n3 at 6:22 PM 3/12/2006
90Integra_Rs
Mar 24, 2009 10:07 AM
silver-16v
Apr 8, 2008 06:13 AM
slow95sedan
Apr 11, 2003 08:27 PM
