B20 install into EG question...
Subscribe
Nov 3, 2003 | 06:05 PM
I have done a search and cant find the answer to my question. I am trying to find out how hard it is to do the actual swap. My plan is to put a B20Z into my 92 CX. Just a stock B20Z, nothing too serious. Daily Driver material. My CX used to have a B16 and was stripped by thieves so I need a new motor. How hard? Any snags you guys have run into? Let me know how difficult it was please. Thanks in advance.
Modified by Rockinfunzone at 10:21 PM 11/3/2003
Reply 0
Nov 3, 2003 | 06:27 PM
Re: B20 install into EG question... (Rockinfunzone)
Very easy as far as the swap goes, there is nothing special at all about it
Reply 0
Nov 3, 2003 | 09:22 PM
Re: B20 install into EG question... (H22EK)
bump
Reply 0
Nov 4, 2003 | 01:58 AM
Did the thieves take just your motor or the whole swap? If just the motor then its just a matter of installing the b20 and wiring it up.
Reply 0
Nov 4, 2003 | 08:32 AM
Re: B20 swap gurus.... (Rockinfunzone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rockinfunzone &raquo;</TD></TR><TR><TD CLASS="quote">I have done a search and cant find the answer to my question. I am trying to find out how hard it is to do the actual swap. My plan is to put a B20Z into my 92 CX. Just a stock B20Z, nothing too serious. Daily Driver material. My CX used to have a B16 and was stripped by thieves so I need a new motor. How hard? Any snags you guys have run into? Let me know how difficult it was please. Thanks in advance.
Modified by Rockinfunzone at 10:21 PM 11/3/2003</TD></TR></TABLE>
If you install the b16 yourself, the b20 should be easy becauase all b series are similar.
Reply 0
Nov 4, 2003 | 10:21 AM
Re: B20 swap gurus.... (ProJectCvic)
They took my motor but left the half shafts and didnt mess with anything else I belive.
I had a shop install the B16, this is my first try at intalling a motor myself.
Reply 0
Nov 4, 2003 | 01:14 PM
Keeping readin about other people mistake and if you have any machanical experience, i say go for it
B series are piece of pie
Reply 0
Nov 4, 2003 | 08:08 PM
i did my first b series about a month and a half ago, and if you have any common sense at all, and a decent set of tools, youll be set. its cake...
Reply 0
Nov 5, 2003 | 11:23 PM
Re: (LsVtec92Hatch)
Coo, I cant wait.
Reply 0
Nov 6, 2003 | 12:32 AM
Re: (LsVtec92Hatch)
The mechanics of the swap are tedious like any swap but easy. The wiring on the other hand is a bitch.
Reply 0
Nov 6, 2003 | 04:09 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rockinfunzone &raquo;</TD></TR><TR><TD CLASS="quote">My plan is to put a B20Z into my 92 CX. Just a stock B20Z, nothing too serious.</TD></TR></TABLE>
It is a very easy and straight forward swap. The only wiring you will need to do is to convert to a 4 wire O2. This might already be done on the cabin side since you had a B16 in there, but depends on how it was wired it up.
You'll need a B series hydro tranny, LS intake manifold (94-95 LS), and an OBD1 LS ECU to run the motor. You said that the axles were left, so you could reuse those by getting the proper intermediate shaft.
Reply 0
Nov 6, 2003 | 07:06 PM
Re: B20 swap gurus.... (VTECVillain)
Check signiture for my intermediate shaft for sale, its packed up and ready to go. I was going to install a b20/vtec into my 94 dx and I bought my intermediate shaft then. Now with my Type R swap installed I have an extra one lying around.
Reply 0
Nov 9, 2003 | 03:12 PM
Do I have to use a 94-2000 LS intake manifold or can it be from an older LS? I compared pictures and they are pretty much the same except for small differences. Can I use an older one? Its all LS and I dont think they chanteg it much.
Reply 0
Nov 9, 2003 | 05:30 PM
yes you can. The obd1 just a better flow though.
Reply 0
Nov 9, 2003 | 07:32 PM
Just for reference but the LS and CRV heads are the same. Buy a long block and the swap will be a breeze.
Reply 0
Subscribe
