b20 cel with bigger throttle
Old Mar 28, 2013 | 05:19 PM
radicaled434's Avatar
Default b20 cel with bigger throttle
So I've been running a b20 with stock tb and sk2 intake with a phearable tun, I just recently put on a professional products 65mm tb and when I use any more then half throttle I throw a cel
I can make it to red line in every gear using half throttle now
Do I need to get it retuned or is my tps or map not reading properly
I can't pull the cel becase it goes away as soon as I turn the car off and putting a jumpper in there while its running doesn't do anything
Old Mar 28, 2013 | 06:50 PM
grumblemarc's Avatar
The Grumpiest
Default Re: b20 cel with bigger throttle
Lessee. Installs component that changes the amount of air introduced into the system. Wonders if he needs a retune.
Old Mar 29, 2013 | 05:35 AM
kyden's Avatar
did you calibrate the tps when you put it in?
Old Mar 29, 2013 | 06:11 AM
The Grumpiest
^^That would to it.
Old Mar 30, 2013 | 06:07 PM
Good call
Old Apr 18, 2013 | 04:17 AM
So here's the update
Got it tuned
New o2 sensor
Calibrated the tsp
Changed the map sensor
In 3rd gear when I go over 5k I throw a cel, only if I use more than 3/4 throttle
Cel goes away when car is turned off and back on
Jumpping while car and cel is on does not work
Old Apr 18, 2013 | 06:22 AM
HondaPartsHero's Avatar
Technical Hero
See if you can borrow an ecu and try to jump the code if it comes on. Sounds like an ecu issue.
Old Apr 21, 2013 | 06:50 AM
i drove my friends 93 4dr yesterday and he has a d16z6 in the car, i gave it full throttle from 2nd to 4th and while i was in 3rd gear at high rpms his cel light came on
doing the same thing as mine, i turned his car off and back on, cel went away
only at full throttle at high rpms does it seem to do this
his setup is stock thru and thru, when the cel goes on it feels like both cars have lost power and it takes longer to accelerate
Old Apr 21, 2013 | 08:25 AM
jdmh22eg2's Avatar
2 cars 1 ecu, hmmm you found your problem. /thread
Old Apr 22, 2013 | 10:03 PM
2 cars 2 ecus
1 car is b series, phearable tuned ecu
1 car is bone stock d series, stock ecu
asianeric
Sep 11, 2009 09:35 AM
b18c1wes
Dec 7, 2004 02:50 PM
SuzukaBlueAP2
Oct 16, 2003 02:39 PM
pelotudo
Oct 31, 2002 03:45 AM
lilxvtecxpwr
Oct 18, 2002 08:16 PM
