b18c into 92 cx?
Use the b18c header.
Your not going to run it through the stock cx exhaust are you?
Your stock cat is in the exhaust manifold, so if you buy an after market exhaust, you will need to puchase a cat or straight pipe.
If the exaust is too short, just take it too a muffler shop and they can lengthen it for you, for pretty cheap.
buy a LS header because you can put the o2 sensor in it and run a testpipe or use a gsr header and use the gsr cat because only the gsr and not the LS has the o2 sensor in it. Good luck on which ever you decide to do.
