B18c in EK, few problems
Old Mar 6, 2010 | 12:27 AM
stjohnsafc's Avatar
Default B18c in EK, few problems
Hiya folks
Having a few problems with my EK, have just finished dropping in my B18c (SiR-G Teg, same as GSR) and i have the following problems that i have noticed..
  • On first few start ups i noticed moisture bubbles from between head and exhaust manifold
  • Erratic idling, cold start is steady at 2200rpm then when warm it goes up and down between 1000 and 2000rpm
  • When diving at night with lights on, when i come off the power the headlights get brighter
Anybody able to help me out with these probs?
Old Mar 7, 2010 | 04:42 PM
em18u's Avatar
Default Re: B18c in EK, few problems
i had to adjust my idle at the throttle body when i did my swap,sounds like you need a new exhaust gasket,and for the headlights gettin brighter, owell lol
Old Mar 7, 2010 | 06:28 PM
cruizinmax's Avatar
I had that same issue with my ek with the lights dimming. I believe it ended up being a problem with the ELD. You may search there is a thread on here somewhere.
Old Mar 19, 2010 | 06:28 PM
JPM98EK's Avatar
Make sure everything is grounded securely. & chek exhaust gasket & retorque after a few heat cycles.
jdm styles
Jan 15, 2007 02:44 PM
turnsignalandy
Jan 4, 2007 09:43 PM
vtecvoodoo
Jan 31, 2002 06:29 AM
