B18B1 Swap
Old Feb 10, 2022 | 03:33 PM
Azshios84's Avatar
Default B18B1 Swap
Hello,
I am finishing up rebuilding a B18B1 for my Civic swap. I finished up the long block and putting on the accessories. I have one mount left, and I cannot for the life of me find where it belongs, or what it is for. It is number 9 on the diagram. What size bolts for it as well if possible.
Thanks in advance
Old Feb 10, 2022 | 09:12 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: B18B1 Swap
It is a transmission stiffening bracket. The bolts that go into the block are 8mm x 1.25 pitch (12mm head)... I am unsure of the lengths off the top of my head, but the threaded end should stick out of the base of the bracket about 5/8" to 11/16". The single bolt that passes through the bracket and into the transmission is a 12mm x 1.25 pitch (maybe 1.50 pitch ???) (17mm head) and should stick out the back about an inch.
Old Feb 11, 2022 | 09:10 AM
spAdam's Avatar
Loved
Community Favorite
The lengths and sizes are all in the same parts fiche that you got the drawing from. They all should be 1.25 pitch.
aljoseph95
Jun 27, 2013 09:20 AM
denniscoles
May 4, 2007 05:52 PM
'88civic
Jan 22, 2003 02:45 PM
