B18b Swap Question
Old Sep 14, 2004 | 06:17 AM
EvilCamaroSS's Avatar
Default B18b Swap Question
Yes I searched but didnt find the exact info i'm looking for. As soon as i find a GSR or LS tranny for cheap I'll be swapping the D16Y7 motor out of my 97 Civic LX and swapping in the LS motor and tranny. I'm trying to gather up everything i need before i sstart the swap... So here is the scenario:
I have a wrecked 96 Integra LS Automatic.
What parts do I need out of the Integra and What parts do I need from an outside source. Also Dont assume I know anything Pretend your telling a complete idiot what they need (I'm car inclined just not honda inclined).. Thanks for all info!
Modified by Stealthtwnturbo at 9:30 AM 9/14/2004
Old Sep 14, 2004 | 08:29 AM
Default Re: B18b Swap Question (Stealthtwnturbo)
anyone?
Old Sep 16, 2004 | 01:45 PM
ttt
Old Sep 16, 2004 | 02:04 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: (Stealthtwnturbo)
alot to list please call the shop 909-373RACE we will be more than happy to help
Old Sep 18, 2004 | 09:53 AM
Default Re: (HOOKUPS)
Well since i'm gonna have to write it down I'd much rather someone post it so i can just print it out. thanks for the offer... if i cant get a complete list i'll give u a call
Old Sep 19, 2004 | 12:13 AM
Cnote's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stealthtwnturbo &raquo;</TD></TR><TR><TD CLASS="quote">Yes I searched but didnt find the exact info i'm looking for. As soon as i find a GSR or LS tranny for cheap I'll be swapping the D16Y7 motor out of my 97 Civic LX and swapping in the LS motor and tranny. I'm trying to gather up everything i need before i sstart the swap... So here is the scenario:
Modified by Stealthtwnturbo at 9:30 AM 9/14/2004</TD></TR></TABLE>
Wiring:
CFK
use the CFK sensor off the B series auto harness, this is the harness near the crank pulley. On the LS it should be the 2 wire plug, on you LX harness you'll have to splice into the existing 3 wires. Two of them match colors, the third wire you do not use.
IACV
Next you'll have to change the LX three wire plug to a standard/traditional IACV plug(you won't use the orange colored wire). Need to move one pin on the A harness. If I can remember its A15 to A10 or A11.
O2
you can make extensions for the primary o2 and the sencondary o2. Since you'll be removing the cat from your D16Y7 engine you'll have to get the obd2 cat from your LS donor car.
IAT
Cut, extend, change plug style....all on your personal way of doing things. I personally run the standard B series IAT on my swaps.
OR OR OR
get a 96-98 EX harness and not have to do any wiring except CFK and the o2 fix
Mounts:
Get 99 Si rear mount
Get 99 SI timing belt mount
Get hydro tranny front torsion mount
Shift Linkage:
90+ teg
92+ JDM civic with B series
99-00 SI
washer and holder
Drive train:
Driver side axle
mid shaft/intermiate shaft (94+ LS/GSR, 94+ del slow vtec, 99+ SI, 92+ hydro setup)
Flywheel (89+ b series)
pressure plate (90+ b series)
clutch disk (92+ b series)
flywheel bolts (total of 8)
pressure plate bolts (6-9 pending on your pressure plate and flywheel)
other than that have fun
Old Sep 23, 2004 | 06:35 AM
Trey's Avatar
25 Year Member
Default Re: B18b Swap Question (Cnote)
Just click the link in my sig for a how-to guide.
Skillz
Aug 27, 2006 06:52 PM
Rob!
Jan 26, 2004 08:54 PM
ak1ra
Dec 13, 2003 01:36 PM
todds94teg
Jul 16, 2002 07:00 AM
