B18a1 obd0 engine in Ek???
Old Dec 13, 2012 | 09:31 PM
Quinton Ambrose's Avatar
Default B18a1 obd0 engine in Ek???
Ok I'm lost on what I would need to do to swap a obd0 engine in my Ek 2000 obd2 it's the ex so had the y8 in it Vtec..... I'm wondering what I would need to do to make this happen I've been told to do is get rywire obd0-obd1 conversion kit but I'm also wondering about when I get it inspected I'm not sure on what to do I'm new to this Honda stuff
Old Dec 13, 2012 | 09:36 PM
jbpnoman's Avatar
Default Re: B18a1 obd0 engine in Ek???
It would be helpful if you posted what state you're in, so we can possibly help you with inspection information.
I can tell you right now, that motor is illegal on a federal level for your chassis, but if you have the feds pulling you over, you probably have more to worry about than a mismatched motor.
Old Dec 13, 2012 | 09:43 PM
doood's Avatar
been there done that
why the hell are you swapping in such an old motor anyway?
ib4toogoodadealtopassup
Old Dec 13, 2012 | 10:14 PM
I live in Vermont and i couldn't find 0bd2 engine and got this for dirt cheap off friend for like 80$
Old Dec 14, 2012 | 01:23 AM
HondaPartsHero's Avatar
Technical Hero
Wiring
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faq-obd2-into-obd1-into-obd0-into-vice-versa-wiring-only-1842858/
99-00 civic si rear Tbracket and drivers side mount
99-00 civic si/94-01 integra shift linkage
90-01 Integra axles/99-00 civic si axles
99-00 civic si exhaust manifold or aftermarket header
94-01 Integra/ 99-00 civic si transmission
Old Dec 14, 2012 | 07:34 AM
Now if u do that it will be good no code and can I still buy wire harness from rywire obd0-obd1
Old Dec 14, 2012 | 07:46 AM
kyden's Avatar
that harness will not help you. you need to rewire your oem harness or use a 99-00 ex or si harness.
Old Dec 15, 2012 | 06:49 AM
2Sauced's Avatar
This is what I did. I had a '96 hx (obd2a vtec) with a '93 Ls swap (obd1 non vtec) and I got it to pass smog. After the swap I had 4 cel codes so I had to fix the codes before I went to smog since you cant have any cel codes to pass. So I had to rewire my hx harness to the motor and had to do the cfk bypass trick. Once I finally got the codes cleared I bought the obd2a to obd1 jumper harness and found a p75 ecu to get the motor running right. But to pass I had to swap back to my hx ecu so their scan tool can read it, their scan tool wont read if its obd1, it wont connect and if it doesnt connect you fail. Finally after rewiring my hx harness and doing the cfk bypass trick, my car PASSED !!! Obviously technically I should've failed since I had an obd1 motor in an obd2 chassiss but after some rewiring of my harness and swapping ecus my car had no CEl codes and appeared to be just another regular honda. So daily driving I had the jumper harness with p75 ecu and for smog purposes I swapped back to the hx ecu. So its do able, just need to be a wiring guru or know one. Do some more searching the answers are out there and look up the cfk bypass trick, it'll shed some more light on what needs to be done. Good luck
gsrswapcivic177
Dec 18, 2012 04:07 AM
Four Dr R
Aug 15, 2010 09:44 AM
twentyhurtz
Aug 27, 2009 07:53 AM
Tom123456
Dec 14, 2006 01:11 PM
