B17A questions
b16a has a 396.78 deck height w/1.74r/r, b17a has 419.45 deck height w/1.68r/r, the b18c1 has 449.34 deck height w/1.58r/r.
i hope this helps you on your quest..
B16A & B17A share the same block shell..which means it has the same deck height. The only main differnce between the 2 engines are mainly the crank, rods, pistons, and actual block stamp ID.
B16A's have a so-called perfect rod ratio. A B17A isn't far off from that 'perfect rod ratio' of a B16A.
B16A= 1.74 RR
B17A= 1.62 RR
[Modified by Katman, 2:03 AM 10/1/2001]
[Modified by Katman, 4:28 PM 10/1/2001]
B16A= 1.74 RR
B17A= 1.62 RR
how is it possible that the b17a has a rod ratio 168 if the rod length of 5.208"( 29.92mm) is divided by the stroke of 3.204"(81.4mm). correct me if i'm wrong.
i know honda isn't wrong, it's only what you think is right. are you just memorizing what you read and learning to be great magazine mechanic?
[Modified by da6_b17a, 11:20 AM 10/1/2001]
...just a tidbit of info. There are some typos' in the HONDA service manuals.
For instance, if you look in a 97 or 98 US ITR service manual - it says that the US ITR has a compression ratio of 10.1 which is wrong...its 10.6. Take a look, you'll be amazed!
psegs80
Aug 21, 2006 07:51 PM
Michael Delaney
13
Feb 8, 2005 11:31 AM
