b16a6
I've just got my hands on a 96' del sol which has a b16a6 (latest in b16a series, South Africa version), the car is clean and all stock. I just wanted to confirm that its OBD2 and SiR2. I made some research but wasn't all clear, I'd appreciate some input. Thanks.
Good question. If it's universal all the way across the world (and I'm 99% sure it is), one way to check is to look at the ECU and see which connectors are being used. Check this link to see which one you have:
http://www.hondata.com/techecuid.html
Also, I believe the connector is different on the distributor, one plug vs two plugs, but I forget which is OBD1 and which is OBD2.
