b16a2 into a 97 Hx
Old Apr 9, 2003 | 03:48 PM
Cor ey's Avatar
I can has title
Default b16a2 into a 97 Hx
I want to get a parts list together for swapping a b16a2 into my 97 Hx and was wondering if any of you have done the swap before and know what all you need. I would like to get a list of <U>ALL</U> the parts that I need: mounts, wires, harness, axles..etc..etc. Any help would be great.
Old Apr 9, 2003 | 05:00 PM
nsxmatt's Avatar
Default Re: b16a2 into a 97 Hx (FabolusIconz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FabolusIconz &raquo;</TD></TR><TR><TD CLASS="quote">I want to get a parts list together for swapping a b16a2 into my 97 Hx and was wondering if any of you have done the swap before and know what all you need. I would like to get a list of <U>ALL</U> the parts that I need: mounts, wires, harness, axles..etc..etc. Any help would be great.</TD></TR></TABLE>
Your asking alot. Don't let someone else do the legwork for you, use the search key and find it out for yourself. All the info is out there. We are not going to help you unless you help yourself. Find all you can, make a list and ask if everything looks ok
Old Apr 9, 2003 | 05:07 PM
Newman's Avatar
New User
Default Re: b16a2 into a 97 Hx (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">Your asking alot. Don't let someone else do the legwork for you, use the search key and find it out for yourself. All the info is out there. We are not going to help you unless you help yourself. Find all you can, make a list and ask if everything looks ok </TD></TR></TABLE>
LOL... yup. If you looked like 4-5 posts down, you'd see there was another similar topic already posted, and Trey posted up his site (great EK - B-series swap info), so I'll give you the link to his page: http://www.jspectuning.com/6gen/
Old Apr 10, 2003 | 02:08 PM
Cor ey's Avatar
I can has title
Default Re: b16a2 into a 97 Hx (Newman)
Hehe, thought I might be able to get out a little easy, but I am looking now...thanks for the link it helped a lot.
Old Apr 10, 2003 | 05:43 PM
HXMan's Avatar
I had a b16a2 swap in my old 97 hx..what you will need:
Since you say you are getting a b16a2, get all the mounts from the Si the engine is from if you can...but all you really need is the rear mount, and driverside mount.
Si axles.
To make things easier get a 96-98 Ex engine harness.
If you can get a Del Sol DOHC VTEC ecu(p30). A 99-00 b16a2 ecu will not plug in. You can also use a 96-98 GSR ecu..but it won't have the right VTEC engagement point.
Make sure you have a helms manual too...you will have to add a secondary O2 sensor cuz the Ex engine harness only has one.
viejohombre
May 31, 2010 11:12 AM
dblock020
Dec 9, 2008 10:12 AM
skrewdriver88
Dec 3, 2004 05:06 PM
1.6vx
Nov 21, 2004 08:00 AM
ogwutang
Dec 6, 2003 03:59 AM
