b16a2 into 94ex
Old Sep 26, 2001 | 02:57 PM
Kamin's Avatar
Default b16a2 into 94ex
this is just a question to see if i can use my stock mounts instead of having to buy some. hasport dosent make mounts for the b16a2 only the b16a (first gen) and the GSR. thanks again guys
[Modified by KAMiN, 11:57 PM 9/26/2001]
Old Sep 26, 2001 | 05:14 PM
memphiss13's Avatar
Default Re: b16a2 into 94ex (KAMiN)
yes you can, but while you have the motor out, install some polyurethane motor mount inserts. for later on when you are putting down more power.
Old Sep 26, 2001 | 08:22 PM
Kamin's Avatar
sweet!
how much somthing like that run? im on a VERY limited budget right now
and it is possible to install them later correct?
and are you 100% sure? someone told me i need to replace my front mount if i want to have power steering and A/C and i do, i live in AZ
its freaking hot.
[Modified by KAMiN, 7:07 AM 9/27/2001]
Old Sep 26, 2001 | 10:07 PM
Kamin's Avatar
bump
Old Sep 27, 2001 | 12:58 AM
B18C-EJ1
Guest
Posts: n/a
No, you cannot use your stock mounts for a B16 into your Civic. You need to use the LS/GSR mounts.
The rear t-bracket is different, as is the lower tranny mount and A/C bracket.
If you got a real B16A 2nd gen, you may have the right bracket, but you'd need to check the stamp on it. It should say P30
The mounts you can use are Driver upper & lower torque. Passenger upper tranny & lower torque, and rear mount.
You'll need the Integra T-bracket and lower transmission bracket.
Old Sep 27, 2001 | 08:23 AM
Kamin's Avatar
Default Re: b16a2 into 94ex (B18C-EJ1)
thanks b18c-EJ1
much better, i thought i needed mounts.
[Modified by KAMiN, 5:24 PM 9/27/2001]
Old Sep 27, 2001 | 08:34 AM
3.3.3's Avatar
mounts run about 500....maybe more
[626]95-GSR
Nov 20, 2005 09:15 AM
transitions
Jun 8, 2005 09:03 PM
gear
Oct 10, 2003 07:30 PM
drewlee
Feb 24, 2003 09:03 AM
90CIVICSI
Jan 15, 2002 08:17 PM
