b16a2 in 89 crix questions
Old Jul 29, 2003 | 12:21 PM
NA_crix's Avatar
Default b16a2 in 89 crix questions
1. the fan switch on an a1 block is on the back of the block with two lil nipples to connect to....the a2 block doesn't have it....or is it the sensor sittin on the thermostat housing? if so can i just rewire up to that sensor?
2. the vtec solenoid does not have the lower threaded part for the pressure switch? is my best bet to get the a1 lower vtec solenoid housing?
3. can i wire straight to the a2 map sensor and get rid of the one on my firewall? (oh, and how about that charcoal canister, can i ditch that?)
that's the only questions/concerns i'm having with my swap...any help would be greatly appreciated...thanks
Old Jul 30, 2003 | 03:23 AM
NA_crix's Avatar
ttt
Old Jul 30, 2003 | 04:49 AM
VTECVillain's Avatar
Default Re: b16a2 in 89 crix questions (NA_crix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA_crix &raquo;</TD></TR><TR><TD CLASS="quote">1. the fan switch on an a1 block is on the back of the block with two lil nipples to connect to....the a2 block doesn't have it....or is it the sensor sittin on the thermostat housing? if so can i just rewire up to that sensor?</TD></TR></TABLE>
You are correct, just extend the wires on your harness to the thermostat housing and wire it with a normal 2 prong plug.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">2. the vtec solenoid does not have the lower threaded part for the pressure switch? is my best bet to get the a1 lower vtec solenoid housing?</TD></TR></TABLE>
Newer JDM second gen B16A I'm assuming? They don't use a pressure switch. You can either get an older style JDM or any USDM VTEC solenoid or you can simply wire around it. Ask Kenji how to do it I forget and I never wrote it down but I does work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">3. can i wire straight to the a2 map sensor and get rid of the one on my firewall? (oh, and how about that charcoal canister, can i ditch that?)</TD></TR></TABLE>
Yes you can stretch the factory wiring of the MAP to reach the new MAP mounted on the throttle body. I wouldn't eliminate the charcoal canister though. Just hook up all the vacuum lines that you can.
Old Jul 30, 2003 | 02:05 PM
NA_crix's Avatar
thanks for the reply
Old Jul 31, 2003 | 05:42 PM
Default Re: (NA_crix)
I emailed Kenji and he told me the process of wiring "around" the newer JDM VTEC solenoid's that don't use a VTEC pressure switch. Of course you could always get an older solenoid or any USDM one, but this is a lot cheaper and just as efficient.
If the OBDI ECU you are using looks for a VTEC Pressure Switch, all you need to do is:
1.) Cut the wire for the VTEC pressure switch (D6)
2.) Tap into the VTEC solenoid wire (A4) using the ECU side of the wire that you just cut at D6.
Other OBD ECU's have the pinouts in different locations but you use the same procedure.
Old Aug 1, 2003 | 05:48 AM
NA_crix's Avatar
thanks for the response. I think I'm going to find a lower piece with the threaded portion for the pressure switch. Thanks for your input.
dls_tech
Dec 11, 2010 07:36 AM
bb6guy
Oct 25, 2010 04:27 PM
G60
Dec 12, 2006 07:40 PM
deftones0817
Oct 14, 2004 07:18 PM
15psi of fun
Aug 26, 2003 08:27 PM
