B16A Vs D15B (Forced Induction) Vs B18c ???
Hello People,
Im new to this forum thingy but its the best way to find answers to my questions. I currently drive a little Civic EG running a pussy D15B. Its slow, non responsive and ultimately, nothing special. My car is currently metallic blue. I am running a twin system out to quad tips. Its lowered on Pedders and on king springs. Car is wearing black widow front bar, buddyclub 2 sideskirts and buddyclub 2 rear bar. Front is carrying a CF buddyclub bonnet. I have a couple of options, mainly relating to engine comparisons. 1st Option. B16A, Toda Stage c Camshaft, Toda Valve Springs and retainers, Motec ECU. 2nd Option. B18C JDM DC-2 Type R (stock) 3rd Option. Rebuild D15B and feed it T3/4 turbo. The purpose is to get this car nice and balanced. Nice and constant power and of course, smoke a few v6s while im @ it. It will be driven on a daily basis so nothing too hardcore. :D Also, I like the shape of the EG so changing to another car is not possible. *My pocket is limited to around the 10k mark* Let me know what you guys think and gimme some feedback. Modified by misterpoh at 8:28 PM 11/28/2005 Modified by misterpoh at 10:03 PM 11/28/2005 |
Re: B16A Vs D15B (Forced Induction) Vs B18c ??? (misterpoh)
You said this car would be daily driven and you have 10k, I would invest in a stock B18C and invest in something else. When I say B18C, I'm talking about a GSR. What B18C are you talking about? JDM Type R.
i wouldnt go boost cuz your DD it.
d15b has not much aftermarket support AKA rods. If you want to really make good power you have to go with a d16 go b18c |
B18 GSR
Turbo D16Z6, if you build it right it will be totally reliable and faster than an all motor b-series. Check out d-series.org and turbod16.com
Re: (thehatchninja)
b18c fow now....boost it later!
d series turbo https://honda-tech.com/forums/images/smilies/emthup.gif
GET A KSERIES. I CAN GET YOU A K20/K24 SWAP FOR 6G'S, AND IT WILL BE A GOOD DAILY DRIVER AND WAY FASTER THEN ANY B-SERIES MOTOR.
Re: (meunit910)
THAT SOUNDS GREAT MAN, please don't use caps.
Re: (d15singlecammer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d15singlecammer »</TD></TR><TR><TD CLASS="quote">THAT SOUNDS GREAT MAN, please don't use caps.</TD></TR></TABLE>
SERIOUSLY! ... And Seriously! https://honda-tech.com/forums/images/smilies/emwink.gif |
Re: (Average Al)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Average Al »</TD></TR><TR><TD CLASS="quote">d15b has not much aftermarket support AKA rods. If you want to really make good power you have to go with a d16
</TD></TR></TABLE> it's been proven that d15b and d16z6 rods are identical. so far the only thing you'll have trouble finding for the d15b are pistons https://honda-tech.com/forums/images...s/emthdown.gif |
Boost the d it will beat b16 and b18 all day
Re: (DYRcivic)
I'd definately get the B18C https://honda-tech.com/forums/images/smilies/emthup.gif
Re: (black_dohc)
GSR motor has much stouter internals and when you want to go faster later (you will, trust me, speed is addictive) boost it. Turbo LS is not a bad idea, I have a friend running the same setup running in the lower 12s in a hb with stock internals (im still a bit confused on how they did it), with tuning of course.
honestly, the turbo d15 can and will smoke those other motors,
but you'd probably want to do a turbo d16, if you're rebuilding it.. |
b18c defo! https://honda-tech.com/forums/images/smilies/emthup.gif much more potential and not gonna have a problem with low torque like the d series! b series all the way!!!!!
Re: B16A Vs D15B (Chris_V-TECH)
Re: B16A Vs D15B (johniericeboy)
h22!
Re: B16A Vs D15B (solsi2000)
Thanks for all your replies. B18C maybe the best way to go..
Re: B16A Vs D15B (d15singlecammer)
if you have 10000, K is the only way. You can get it done with less than 10g's with haggling and very diligent pursuit of a good deal. Its only going to cost me around 7300 if i do all the work myself which i will.
get a k20...or a b18c5 and call it a day....
what about b20vtec?
that's another hammer of a motor imo.. |
Re: B16A Vs D15B
everyone is always going to say B and jump on the bandwagon, seems you've made up your mind anyway as to what you want to do.
I say boost the D and smoke B16's, B18's B 20's all day long with a smile on your face. I wouldn't even consider K cause of the cost. You could get a nice D16z6, build it up STRONG with a really good turbo kit for under 5k.......do some homework and don't give into peer pressure. Good luck. VIVA LA D |
