B16A question
Old Oct 13, 2006 | 10:20 PM
EG6LS's Avatar
Default B16A question
Searched but did not find a satisfactory answer. Just finished swapping a Japan Spec B16A in to 92 Civic DX. When I bought the car it had an LS engineit it. The B16A is 95 SiR II. I kept the same OBD Type as the car to minimize electrical work. The problem is that it will start, but when I give it gas it dies. Checked all the grounds, and replaced fouled spark plugs today. I made a little bit of difference, but it still runs poorly and still dies when I try to rev the engine. Any thoughts?
Old Oct 14, 2006 | 03:33 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: B16A question (EG6LS)
check to make sure you didn't swap around the TPS and MAP sensor plug since they are the same type plug
Old Oct 14, 2006 | 10:54 PM
EG6LS's Avatar
Default Re: B16A question (HondaPartsHero)
The engine is running good now. Myself and a buddy fixed that problem this afternoon. Still have CELs for
MAP Sensor
Crank Position Sensor
TPS
Engine Coolant Temp Sensor
IACV
Could this be that they are just not functioning properly or are they still mixed up possibly. The Engine doesn't die when I give it gas anymore just want to clear the CELs
daniel990836
Oct 7, 2009 04:20 AM
velisma
Feb 6, 2009 06:08 AM
B16A JDM EG
Apr 3, 2007 04:10 AM
amber_eg6
Dec 17, 2004 05:29 AM
