b16a problem's
Old Aug 26, 2005 | 12:51 PM
SiR_Injected's Avatar
Default b16a problem's
did the swap pretty well done .. shuld have done this b4 the motor was in is to crank it by hand ...anyways its in thecar and seized as ****.. is there any thing i can do to break it free.. since the tranny is in too im thinkin on d/c the engine from there and leaving that all in thereif i have to ill take the pan off and head..
Old Aug 26, 2005 | 03:07 PM
Adam.C's Avatar
Default Re: b16a problem's (dubz01si)
WTF u just say?
Old Aug 26, 2005 | 03:16 PM
Default Re: b16a problem's (orangerex04)
my engine seem's to be sized mang!
mightg have to take it apart but i dont want to i was wondeing if i can add somthing threw the spark plug holes in the piston chamber to unsieze better ?
thats what the **** im sayin
Old Aug 28, 2005 | 02:52 AM
civic2slo's Avatar
Well first of all is it seized from water being in the cylinders? Or seized from a bad rod/crank? Take out a spark plug and see if you see any rust. if not. You can guess. BTW where did you get the b16a from? Does it have warranty? If so best bet is to return it.
runeminaEF9
Apr 2, 2006 09:44 AM
Black4thgenEF
Dec 19, 2005 07:29 PM
thinknology
May 27, 2004 02:15 PM
JDMCRX
Apr 13, 2003 01:41 PM
