b16 head on b18block
Old Jul 16, 2007 | 12:08 PM
paddy b's Avatar
Default b16 head on b18block
ive tried searching but to no avail, so theres bound to be someone out there who has tried this, have a b16a in my integra, but i have a rebuilt bottom end of a b18c, will the two work in harmony or will it just blow up, i can get my hands on a b18 head, but apparently the b16 inlet manifold wont fit a b18 head? im so confused.
cheers paddy
Old Jul 17, 2007 | 03:03 PM
gibsanez's Avatar
Default Re: b16 head on b18block (paddy b)
you must not have searched very hard. Search Poormans type R. You put a B16 head on a B18C block.
A GSR intake manifold will not fit on the PR3 head.
Old Jul 17, 2007 | 07:40 PM
b18c1ej8's Avatar
the b16 head will fit a b16 head or a type r head but not a gsr
Old Jul 18, 2007 | 02:11 AM
gibsanez's Avatar
Default Re: b16 head on b18block (b18c1ej8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1ej8 &raquo;</TD></TR><TR><TD CLASS="quote">the b16 head will fit a b16 head or a type r head but not a gsr</TD></TR></TABLE>
Get that misinformation bullshit out of here. A B16 head WILL fit on a GSR block.
Old Jul 18, 2007 | 05:26 AM
GSR-C5's Avatar
Default Re: b16 head on b18block (gibsanez)
i also have a b18c5 block that need a head. i'm looking to buy a B16 head. will i be ok to use my C5 mani and cams shafts?
Old Jul 18, 2007 | 07:36 AM
5_Lug_B's Avatar
* B A N N E D *
Default Re: b16 head on b18block (eg585)
You can fit it perfectly. But when you put a B16 head on a GSR block you lower the compression which can ideal for boost but if your going N?A id reccomend changing the pistons.
Old Jul 18, 2007 | 09:49 AM
b18c1ej8's Avatar
Default Re: b16 head on b18block (5_Lug_B)
my bad i meant to say a b16 manifold will only fit b16 or type r head,where a gsr manifold can only stay on the gsr head
jayswizz
Oct 7, 2015 06:34 AM
sick93sol
Apr 11, 2009 07:18 AM
blanco617
Aug 7, 2007 04:36 PM
maxheat
24
Feb 26, 2005 12:36 PM
MrSmith
Mar 23, 2002 01:30 PM
