B-series ECU's
They have a barcode on the outer case with the code. There is also a sticker that tells what it is on top of the connector side but it's not as visible. Beware though because it is easy to swap the ecu board into another case.
Does the ECU have a stamping on it that tells which ECU it is? If so so where is it stamped? Any help would be great. Thanks
beanerman
Jan 8, 2006 04:05 PM
