AP2 Cluster in an EG6 - Help!
Old May 7, 2008 | 12:24 AM
silverprop's Avatar
Default AP2 Cluster in an EG6 - Help!
Does anybody have experience with the AP2 cluster in a '92 EG6?
I can't get the door open lights to work. I can't get the Modifry ECT to work (Shows Full even when cold.) I can't get the fuel level to be accurate. (It showed half a tank when i knew i was running on empty. The swirling of the fuel causes the level to be erratic unless i disconnect the constant 12V to the cluster) Doing this makes me lose the clock and the speed will always reset to MPH when I need KM/H
Here is how i wired it. Do note that i wired it to a DC2 cluster plugs coz that was what i had in there before.
A1 – A7 – Not Connected
A8 - DC2 Cluster Illum
A11 – A14 – Not Connected
A9 – IGN 12V
A10 – Constant 12V (For my install A9 and A10 are always powered when I turn my key, not sure if this is correct. The race style key powers everything on.)
A15 – High Beam from my DC2 Cluster plug
A16 – A18 – GND (all on same wire)
A19 – Not Connected
A20 – A22 – Not Connected
B1 – B2 – Not Connected
B3 – DC2 Tach Signal wire
B4 – Not Connected at the moment.
B5 - Modifry ECT ( Shows my car is overheated when engine is cold )B6 - B7 - Not Connected
B8 – B9 – Not Connected
B10 – Fuel Gauge
B11 – B14 – Not Connected
B15 – B18 – Not Connected
B19 – SRS turned Off (Either 12V or GND)
B20 – GND (same as A16-A18)
B21 - EPS turned Off (Either 12V or GND)
B22 – Not Connected
B23 – DC2 Parking Brake wire
B24 – B25 – Not Connected
B26 – DC2 Alternator wire
B27 – Not Connected (Previous owner did not connect this wire when he put the DC2 cluster into my EG6 can’t find it in the loom)
B28 – DC2 CEL wire
B29 – B30 – Respective turn signals.
wow_ohoh
Jun 29, 2009 08:16 AM
civiccpedx
May 18, 2007 06:56 PM
B_CRUZ!
Northern California (Sales)
Nov 10, 2005 10:49 PM
