alternator problem!!!!!!!!!
Old Jan 26, 2002 | 08:56 AM
topher's Avatar
New User
Default alternator problem!!!!!!!!!
i am wiring in a b16a2 jdm spec into my 1996 del sol si with d16y8
heres the problem
I am using the us spec wiring harness from the d16y8, and it will not attatch to the jdm alternator due to the fact that the US spec harness has a 3wire plug alternator
and the jdm harness has a 4wire plug alternator
the 4 wire japanses one says it is internally regulates
i guess this refers to voltage regulation
so i need to put the japanese alternator on, but I need to know what to do with the extra wire!
right?
and how and where do i wire it?
next question...is the b16a2/3 UNITED STATES AND CANADA spec alternator 4 wire plug as well?
not that that would help, just wondering
i mean, if the alternator is self regulating, why does it have an extra wire, and where do i wire it to!
Old Jan 26, 2002 | 07:53 PM
Kamin's Avatar
Default Re: alternator problem!!!!!!!!! (topher)
ok first
the b16a2 is from a 99+si
the b16a3 is from a 93-96 del sol.
the jdm b16a is from a 91-95 sirII
what motor do you have.
second. it shouldnt matter which one you have. i have a jdm b16a in my 94 civic
worked fine no problems.
just make sure you wire the alternator into the battery.
[Modified by KAMiN, 4:53 AM 1/27/2002]
redline5th
12
Jan 26, 2025 05:13 PM
user 20002452454
Dec 8, 2021 03:58 AM
topher
Jan 26, 2002 11:00 AM
