altenator belt for h22 swap w/o ac???
I need a altenator belt for my h22 in my 95 civic w/o ac. I tried the 36" belt but it was to long.
I couldn't tighten it up due to the headlight housing. Should I just find a 35" belt or what should I do? any info would be great https://honda-tech.com/forums/images/smilies/embeer.gif |
Re: altenator belt for h22 swap w/o ac??? (eg_h22)
If the alternator has an aftermarket pulley on it take it off. Mines in an em1 and the aftermarket pulley caused me all kinds of problems.
Re: altenator belt for h22 swap w/o ac??? (botlebruiser)
no it has the oem pulley. the alternator pulley hits the housing before the 36" belt is tight.
what do I do? |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_h22 »</TD></TR><TR><TD CLASS="quote">no it has the oem pulley. the alternator pulley hits the housing before the 36" belt is tight.
what do I do?</TD></TR></TABLE>go with a smaller belt. next size down or two sizes down depending on how loose it is. |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_h22 »</TD></TR><TR><TD CLASS="quote">I need a altenator belt for my h22 in my 95 civic w/o ac. I tried the 36" belt but it was to long.
I couldn't tighten it up due to the headlight housing. Should I just find a 35" belt or what should I do? any info would be great https://honda-tech.com/forums/images/smilies/embeer.gif </TD></TR></TABLE> or you can just run the alternator relocation bracket. it saves a lot of room. and uses a 32" belt. Innovative makes a great one... see my Sig. |
Re: altenator belt for h22 swap w/o ac??? (h22crxpwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22crxpwr »</TD></TR><TR><TD CLASS="quote">
or you can just run the alternator relocation bracket. it saves a lot of room. and uses a 32" belt. Innovative makes a great one... see my Sig.</TD></TR></TABLE> do you have pics of it installed? never seen one |
do you have pics of it installed? never seen one</TD></TR></TABLE> it relocates the alternator down to where the power steering originally went. works great and saves room. it will be miles away from hitting anything! heres a pic from innovatives site. and a pic of it installed. http://www.innovativemounts.com/v/vs...os/59185-2.jpg https://i9.photobucket.com/albums/a9...ild7656609.jpg |
I'll have to extend my harness some more.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_h22 »</TD></TR><TR><TD CLASS="quote">I'll have to extend my harness some more.</TD></TR></TABLE>
mine reached with no problem. its not that far. and there is slack in mine. unless your harness is super tight? i have a little slack in mine and it reached fine. |
it relocates the alternator down to where the power steering originally went. works great and saves room. it will be miles away from hitting anything! heres a pic from innovatives site. and a pic of it installed. </TD></TR></TABLE> air conditioning actually |
Re: altenator belt for h22 swap w/o ac??? (95greenlude)
anyone have a front view of that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95greenlude »</TD></TR><TR><TD CLASS="quote">
air conditioning actually</TD></TR></TABLE> yeah sorry about that. AC compressor, |
