All B series fly wheels the same??
Old Nov 21, 2002 | 07:12 PM
FredoSP's Avatar
Default All B series fly wheels the same??
Just wondering if a B18B flywheel can fit in a B16A2 (2000 civic si )
Thanks guys!
Old Nov 21, 2002 | 08:08 PM
Kamin's Avatar
Default Re: All B series fly wheels the same?? (FredoSP)
as long as they are both manual transmissions, yes.
Old Nov 21, 2002 | 11:50 PM
HandCommand's Avatar
Default Re: All B series fly wheels the same?? (KAMiN)
Yes, most B series flywheels are the same. Well at least the ones Ive encountered are the same............ The older ones usually have 9 bolts holding the pressure plate, the new ones have 6.
Old Nov 22, 2002 | 12:28 PM
Tuan's Avatar
Default Re: All B series fly wheels the same?? (HandCommand)
One more for the road, YEs they are all the same, the bolts too.
Old Nov 22, 2002 | 01:00 PM
memphiss13's Avatar
Default Re: All B series fly wheels the same?? (Tuan)
88-91's are different from the 92+
Old Nov 22, 2002 | 10:07 PM
Colin's Avatar
Default Re: All B series fly wheels the same?? (rookie2nr)
are you talking weight or general specs.
i know FOR SURE that the 90-91 teg flywheel is the same, fitment wise, as all other b series flywheels...which means its the same, fitment wise, as 89-91 b16a's. Thus all 89+ b series flywheels are interchangable.
i don't believe there was such thing as a b series motor in 88....was there?
Old Nov 25, 2002 | 02:11 AM
"88-91's are different from the 92+" ( rookie2nr )
As I said before.......the older B series flywheels use 9 pressure plate bolts, the newer ones use only 6.
In terms of weight, Ive weighed them and older or newer, they generally weigh about the same. About 17 lbs. The factory Type R flywheel is roughly 15 lbs.
I weighed these all at the same time, using the same digital scale at UPS to make sure there were no variables that affect the readings.
The Aasco Motorsports flywheel weighs just under 8 lbs without the Pilot Bearing installed. Many of the swaps I do sport this flywheel with NO PROBLEMS and great results.
[Modified by HandCommand, 5:12 AM 11/25/2002]
Old Nov 25, 2002 | 11:52 AM
irev210's Avatar
i dunno, i have a type R flywheel and it has 9 bolts not 6
Old Nov 25, 2002 | 10:43 PM
Tuan's Avatar
Default Re: All B series fly wheels the same?? (sirhatchback)
Yup your right, all B-series flywheel have 9. ?
Old Nov 25, 2002 | 11:22 PM
90accord1's Avatar
As stated above, the PRESSURE PLATE BOLT quantity is different. The actual flywheel bolts that attach it to the CRANK is the same.
preludeboybmw
Sep 4, 2008 07:05 AM
Sinner
Jan 27, 2006 08:41 PM
Boosthead
Dec 30, 2004 08:13 AM
FredoSP
Nov 22, 2002 07:29 AM
