About deck height - B18C and B20B?
Old Jul 15, 2009 | 04:00 AM
PARADOX_sf's Avatar
Default About deck height - B18C and B20B?
Hi.
Is there any difference at - B20B/Z and B18C sleeved block deck height? Is there any problem to use pistons for B20B/Z at B18C?
Thank you!
Old Jul 17, 2009 | 12:39 PM
raidacaipo's Avatar
Default Re: About deck height - B18C and B20B?
same height... only different is bore size and crank size. the b18c bore is 81mm and stroke is 87.2mm where as the b20b/z bore is 84mm and stroke is 89mm
Wait so you want to use b20b/z pistons for a sleeved b18c block? or use b18c oem pistons for b20 block? because you cant. The b18c pistons are 81mm
Old Aug 6, 2009 | 07:18 AM
PARADOX_sf's Avatar
I am planning to use b20b/z pistons in b18c sleeved block
Old Aug 10, 2009 | 04:54 AM
ERL Performance's Avatar
Why would you use OEM pistons in a sleeved block? If you've spent the money to get the sleeved block then get a good set of aftermarket pistons with a better profile and better compression. The 2618 alloy of the aftermarket piston is much better than the cast OEM one and if you use like a Wiseco piston, most of their shelf stock pistons come with a skirt coating on them as well.
Old Aug 10, 2009 | 10:51 AM
soxle's Avatar
and bearing rod thickness are different. B20B is like a B18B and B18C bearing is thickless.
and allright with ERL Preformance.
and better: make only a 84mm or 85mm bore B18C: better crank, better block (oil spray) and less stroke then better rpm use.
Old Oct 11, 2010 | 10:40 AM
Romo Pyro's Avatar
B18C: 212.39mm deck height
B20x & B18a/b: 211.84mm deck height
Your compression will vary according to which block you use.
Old Oct 16, 2010 | 07:57 PM
HiProfile's Avatar
I think the OP means a forged piston designated for the b20. As long as it has large enough valve reliefs and a nearly stock compression height, it will be fine. The piston must be [down] in the hole enough to account for rod stretch.
91Honda_gsr
Engine Machining & Assembly
Dec 17, 2015 02:21 PM
PARADOX_sf
Jul 15, 2009 04:36 AM
PARADOX_sf
Jul 13, 2009 02:44 AM
