96-98 civic ex 5spd harness
im planning to put my 99 b16a2 motor in a 96-98 civic hb and im gonna use a 96-98 civic ex 5spd harness. ill be running a hondata chipped p28 ecu so ill have to use a jumper harness of course. i was wondering does that civic ex harness have the crank fluctuation sensor plug? thank you
Re: 96-98 civic ex 5spd harness (tgh99si)
i was just reading katmans swap write up and am i reading this right? if i use a 96-98 civic ex 5spd harness while putting the b16a2 in the 96-98 civic hb, i wont have any problems at all, except some wires may be too short and need to be extended? does everything really plug in including the in the cab? thank you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">i was wondering does that civic ex harness have the crank fluctuation sensor plug?</TD></TR></TABLE>
Yes <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">ill be running a hondata chipped p28 ecu so ill have to use a jumper harness of course.</TD></TR></TABLE> Running a P28 you won't need to worry about the crank fluctuation sensor because the OBD1 P28 ECU doesnt look for that sensor. |
Re: 96-98 civic ex 5spd harness (VTECVillain)
so that harness will work perfectly, the cab and motor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgh99si »</TD></TR><TR><TD CLASS="quote">so that harness will work perfectly, the cab and motor?</TD></TR></TABLE>
Yes indeed. The 96-98 EX harness is nearly all plug and play and the best harness to use for any VTEC motor in a 96-98 EK chassis. |
alright, sounds too easy, haha. thank you villain.
so what purge solenoid do i use when i put the b16a2 complete motor in the 93-98 civic hb?
