94+ Teg and Del Sol VTEC AC bracket the same?
Old Jun 20, 2002 | 04:08 PM
boomslang's Avatar
Default 94+ Teg and Del Sol VTEC AC bracket the same?
Just need to know...
Old Jun 20, 2002 | 05:23 PM
kenji's Avatar
Default Re: 94+ Teg and Del Sol VTEC AC bracket the same? (Inlinefour)
No they are not the same.
The '94-up 'teg AC bracket will have P30 cast into it.
The '94-'95 DOHC VTEC Del Sol AC bracket has P54 cast into it.
-kenji
Old Jun 20, 2002 | 06:22 PM
boomslang's Avatar
Default Re: 94+ Teg and Del Sol VTEC AC bracket the same? (kenji)
Thanks. I should have been more specific. Will both work for a 92-95 Civic AC compressor?
Old Jun 21, 2002 | 09:02 PM
JD_B18CDX's Avatar
No it wont. Only the one from a DOHC vtec del sol will work.
If u want to user stock civic compressor u need the Del Sol.
IF you want to use the integra compressor, u need to modify AC lines.
Old Jun 21, 2002 | 11:54 PM
sparkz's Avatar
Default Re: 94+ Teg and Del Sol VTEC AC bracket the same? (johnd)
you can also use a bracket off of the 99-00 Civic Si's.
CivicTT
Jul 19, 2010 11:22 AM
ThE BiG RauL
Apr 14, 2006 10:14 PM
JinDIESEL
Sep 3, 2004 05:54 AM
roc
Feb 29, 2004 06:01 AM
