90-93 Rear Disc brake swap onto 93 EG
It seems that everyone is doing either 90-93 rear discs on EF's and 94-up Or GSR rears on EG's...
My deliema is I have a 90 Integra parts car and a buddy has a 93 coupe... Do the DA trailing arms and everything else swap right over to the EG? If not what needs to be done? Do the disc's/calipers bolt onto the stock EG trailing arms? Would this be too much of a PITA compared to a gsr setup? Any info is helpful!! TIA! Dev |
Re: 90-93 Rear Disc brake swap onto 93 EG (Dev90gs)
yes it will
Re: 90-93 Rear Disc brake swap onto 93 EG (SupaFly_Honda)
yes it will what?
Theres like 4 questions in there... It will bolt right up? So I just follow the basic procedure as any other rear brake swap? Thanks for the help! Dev |
just take the arms and slap them on, your gonna need another ebrake cable though (i think)
Alright cool thanks!
Dev |
Re: (Dev90gs)
which ebrake cable do you need with the 90-93 integra rear brakes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dev90gs »</TD></TR><TR><TD CLASS="quote">Do the DA trailing arms and everything else swap right over to the EG? </TD></TR></TABLE> YES they do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dev90gs »</TD></TR><TR><TD CLASS="quote">Do the disc's/calipers bolt onto the stock EG trailing arms? </TD></TR></TABLE> well, you can undo the 32mm Hub bolt and the four TORX bolts behind the hub and remove the entire drum-brake setup from the triling arm and do the same to the disc-brake setup to swap the disc-brake setup onto your civic trailing arms. BUT sometimes the torx bolts or the hub/axlenut re major PITA so be prepared for some work if its an old old car. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dev90gs »</TD></TR><TR><TD CLASS="quote">Would this be too much of a PITA compared to a gsr setup?</TD></TR></TABLE> too much of a PITA?...nope, same kind of deal. |
