Old Jan 12, 2005 | 08:17 PM
azzinine1's Avatar
Default I NEED HELP...distributor wiring for 93 jdm h22 in 96 accord, already searched a lot
I swapped a 93 JDM H22A into my 96 LX Accord i know this is a really popular swap and someone is likely to know this. I already posted it in the accord forum but no answer yet so this seems like a good forum to post it.
Im trying to finish the wiring on my Dizzy i have all wires figured out except 2. There is a Lime wire (or light green wire whatever you may call it) that was in a clip with 3 other wires this clip connected to the accord dizzy, the other 3 wires were Black, Yellow/Green and Yellow I figured out those three but where does that lime one go. The other wire is a Yellow wire that was in a clip with a blue wire that also conected to the accord dizzy but also fits a clip on the prelude dizzy. I found that since i amconverting to an internal coil i am suppose to splice the black/yellow wire with the solid yellow wire from the clip that used to connect to the external coil, and that the green wire from that clip is no useless.
So to simplify this a bit should i also splice that first yellow wire i mentioned into the yellow wire spliced with the yellow/black wire from the external coil clip...that would make 3 wires conected to the black/yellow wire going into the dizzy...is this right or not???Thanks for your time
DannyBoy310
Apr 3, 2012 07:17 PM
90_EX_Civic
Mar 21, 2009 07:59 PM
