4 wire 02 sensor installation help
Old Jan 11, 2004 | 05:55 PM
SI_Ro's Avatar
Default 4 wire 02 sensor installation help
I need a little help/clarification on how to wire the 4 wire 02 on my 1st gen B16. I am currently using a OBD0-OBD1 conversion harness from Boomslang. Their instructions say to add 3 wires and use the existing o2 wire on the OBD0 harness. Basically what I'm asking is, is do I just solder the 4 o2 sensor wires to the conversion harness (not using any plugs/connectors)? I'm just asking because if I solder these wires, what happens when the o2 goes out? That means I'll have to cut the o2 off and resolder a new sensor on, right?
Old Jan 12, 2004 | 06:43 AM
4crx4me's Avatar
Default Re: 4 wire 02 sensor installation help (SI_Ro)
If you solder all the way from ECU to 4 wire o2, you will be sorry.
I'm in the middle of figuring this out right now, myself.
Right now I'm thinking of using 3 connectors for the o2 wiring.
1 right at the ECU inside the cabin, 1 at the shock tower just like the stock harness and one just above the o2, also the way the stock harness is set up.
This way, if I need to replace the o2 itself, or any piece in between it will all just unplug.
killerb7888
10
Oct 29, 2013 07:47 AM
EX-T
12
May 24, 2008 08:01 PM
Hondamonster
12
Jun 21, 2007 08:19 PM
91dx-92ex
Jan 25, 2006 08:37 AM
SlippylesKB
Aug 3, 2003 12:32 PM
