****LS B18 SWAP IN 98 CIVIC *** HELP!!!!
I need to know what I can use & what I can't, for this ls swap into my 98 civic that had a d16y7
B18b motor is sitting in a EF chassis they swap will come with the following: *engine harness *ecu *axles *shift linkage I also have solid mounts wondering if those will work for my swap?? I know single cams have a 2 post & b series have 3 posts I heard something about me needing the axles & a half shaft? If the motor is already sitting in the car can I just plug & play everything?? |
Re: ****LS B18 SWAP IN 98 CIVIC *** HELP!!!!
Im doing the exact swap into my 98' haha.
This link (which is a sticky in this sub) has everything needed to know about this. Very detailed, very helpful. https://honda-tech.com/hybrid-engine...A-%2A-1972711/ GL |
Originally Posted by WiscoEx
(Post 50493940)
This link (which is a sticky in this sub) has everything needed to know about this. Very detailed, very helpful. https://honda-tech.com/hybrid-engine...A-%2A-1972711/ GL VERY MUCH APPRECTIATED! THANK YOU |
