Honda S2000 Honda S2000
Shaking in the rear when accelerating. Need Help!
Old Aug 15, 2007 | 11:49 AM
kid vtecnik's Avatar
Default Shaking in the rear when accelerating. Need Help!
Like the title says my MY00 S2k is shaking in the rear when i accelerate, it just started happening about a couple of days ago. I do have clutch buzzing when the car deccelerates, but i know thats somewhat normal. The only thing i can think of is the driveshaft due to the car being low(but car is only lowered on skunk2 springs). The shaking is only noticable at about 40+ mph. help me out!
Old Aug 15, 2007 | 11:55 AM
apSquidFace's Avatar
* B A N N E D *
Default Re: Shaking in the rear when accelerating. Need Help! (kid vtecnik)
bent wheel, unbalanced wheels, crappy tire wear, recent alignment???
any of those could be causing this...i had the same prob and my right rear wheel was out of round. got new wheels no more vibration.
Old Aug 15, 2007 | 12:07 PM
Mr. Projekt's Avatar
* B A N N E D *
Check tires pressures, alignment, CV joints, and re-torque the axle nuts to 220 lb/ft.
Old Aug 15, 2007 | 12:14 PM
coo, ill def. check out all those things. kinda weird cause i havent touched **** on the car for months.
Old Aug 15, 2007 | 12:18 PM
* B A N N E D *
Default Re: (kid vtecnik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid vtecnik &raquo;</TD></TR><TR><TD CLASS="quote">kinda weird cause i havent touched **** on the car for months.</TD></TR></TABLE>
That could be the problem. Monthly checks are the key.
Old Aug 15, 2007 | 12:30 PM
* B A N N E D *
Default Re: (Mr. Projekt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Projekt &raquo;</TD></TR><TR><TD CLASS="quote">
That could be the problem. Monthly checks are the key. </TD></TR></TABLE>
wizzzuuurd brutha
Old Aug 15, 2007 | 08:28 PM
ReddotsS2K's Avatar
check ur belts and everything and make sure everything is aligned. my car did the same thing and it was my alternator cracked.
Old Aug 15, 2007 | 09:04 PM
bky's Avatar
bky
retorque your lug nuts. it's free and it might be the problem (probably not, but it's still free)
Old Aug 16, 2007 | 07:40 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: (bky)
well to fix the problem when my girlfriend starts to shake in the rear... i just accelerate more... this usually fixes the problem... if not just put some fluid on her back and she'll stop shaking for sure...
on a serious note... def check the lugs, rims, tread and what everyone said above... let us no how it turns out...
Old Aug 16, 2007 | 09:12 AM
frankdatank's Avatar
its the axles. same thing happend to me. you can either buy new ones or switch the inner shadts from left to right. thats what i did. no more vibration.
Old Aug 16, 2007 | 02:03 PM
g2kap1v2's Avatar
Default Re: (frankdatank)
I would mainly check the alignment, torque of bolts, and axels. most of the other suggestions you should be able to feel all the time(0-40 mph).
homeskillet
Oct 14, 2010 02:24 PM
JonasG
Nov 12, 2006 02:07 PM
thegeorge613
Aug 10, 2006 06:40 PM
ernestoG
Jul 23, 2006 07:18 PM
Flux
Feb 2, 2002 11:25 AM
