Honda S2000 Honda S2000
s2k wont start? :(
Old Sep 4, 2008 | 10:47 PM
abi_cruz's Avatar
Default s2k wont start? :(
hey guys whats up, so i was out of town for a while, and i left my car in the garage. and now that im back my car wont start at all
i checked pretty much everything but nothing, the battery and all, the car wont even make any noice at all, dont know what could be the problem. any suggestions? plz help, thanks guys.
Old Sep 5, 2008 | 04:05 AM
chimmike's Avatar
if the car won't make any noise at all or attempt to crank over=====BATTERY!
Old Sep 5, 2008 | 07:39 AM
abi_cruz's Avatar
naw thats not it, i even put in a new battery and still nothing
Old Sep 5, 2008 | 07:50 AM
Chris.'s Avatar
Honda-Tech Order of Merit
Default Re: (abi_cruz)
check all of your fuses, how long was it sitting for
Old Sep 5, 2008 | 07:52 AM
abi_cruz's Avatar
for about two months, yeah i haven't check the fuses yet. ill do that. anything else that might be wrong besides the battery or fuses? ignition or starter maybe?
Old Sep 5, 2008 | 10:16 AM
Lsos's Avatar
Default Re: s2k wont start? :( (abi_cruz)
Might sound like a stupid question, but did you press the START button?
I actually heard of people with your same situation and that turned out to be the problem...
Old Sep 5, 2008 | 11:05 AM
Firstoost's Avatar
Default Re: s2k wont start? :( (Lsos)
I doubt he forgot how to start his car in 2 months
Old Sep 5, 2008 | 11:41 AM
dagle's Avatar
Default Re: s2k wont start? :( (Firstoost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Firstoost &raquo;</TD></TR><TR><TD CLASS="quote">I doubt he forgot how to start his car in 2 months</TD></TR></TABLE>
dunno man, have u seen honda-tech lately?
sounds like battery tho OP
Old Sep 5, 2008 | 11:54 AM
ReddotsS2K's Avatar
Default Re: s2k wont start? :( (dagle)
OP, describe what is heppeneing...are all your gauges powering on and the radio coming on?i am thinking it could be a loose ground...maybe a start switch or a starter selenoid. (Have had all these go bad on my other cars)
Old Sep 6, 2008 | 10:01 AM
abi_cruz's Avatar
Old Sep 6, 2008 | 11:35 AM
Ross 2.0's Avatar
In a Junkyard near you.
Check for battery voltage and grounds
Old Sep 6, 2008 | 11:37 AM
AznX TL's Avatar
its your battery.
Old Sep 6, 2008 | 12:31 PM
chimmike's Avatar
that's what I said.
check your terminals
Old Sep 6, 2008 | 12:37 PM
abi_cruz's Avatar
ok i will double check everything. thanks guys
Old Sep 6, 2008 | 08:36 PM
megalomaniac001's Avatar
The fuses for the stating circuits are under the hood so I'd start there. If those check out, then check the ones in the car. And if THOSE check out behind the drivers kick plate (the one with the fuse cover in it) is one of the starter relay wires. Its a 12 gauge(thicker then most of the other wires) black wire with a white strip. Put a volt meter on it and check to see if its getting power when you press the start button. If you have voltage then It's more then likely your starter. If no power its you ignition wiring. Happy hunting!
Old Sep 7, 2008 | 12:08 AM
supasweetr34skyline's Avatar
shoulda bought a h0onda so i hear
SwiftTypeR
Jan 3, 2008 06:46 AM
nighttrain33
10
Feb 25, 2007 08:10 PM
cilvia
Dec 30, 2006 10:49 AM
4runner
10
Jun 20, 2005 08:40 PM
[626]95-GSR
14
Feb 27, 2003 07:45 AM
