s2k +35 offset wheels
hello,
i found some wheels on ebay that i really like for my s2k and also very cheap. but im not sure they will fit. here is the link. any help is much appreciated.
http://cgi.ebay.com/ebaymotors/17-Wh...Q5fAccessories
They will easily fit cause they are only 8" wide.
You will need a slight roll/bumper tab relocate in the back if you plan to run anything bigger than a 235 tire and your car is lowered.
You will need a roll in the front along with a fender liner trim if you plan to run anything bigger than a 215 in the front and your car is lowered.
What size tire? What suspension (spring rates) and how low? Whats the purpose of the car and how do you want it aligned. (ie do you care about handling and tire wear or do you just want it to fit?)
Yo Midwesta, where did you get your car aligned? GT Motoring is going to be roling my fenders as soon as it gets nice out but im going to have to get it aligned...sadly a lot of places around my house can't align car that are dropped.....
i just want it to fit lowest possible ride height.
I can most likely have it aligned at the same time you have the fenders rolled, it will be $75 extra.
225 will make it easier all around... but even then you will need to roll front and rear fenders and relocate the rear bumper tab and trim the front fender liners. Especially if you want it low. You will also need to run some camber but not a crazy amount since a 225 and a 235 is slightly stretched onto a 9" rim.
From: home of Marciano/Haggler, city of champions, MA
yea cause snap oversteer is a b*tch.
Also I think it is recommended to have 30mm of tread width between the front and back tires on the s2k. But I'd imagine this pertains more to an ap1 because of no bumpsteer kit
Cool Cool Island Breezes. BOY-EE
The irony is that your license plate says "grp hard". Maybe change it to "prk hard"?
Get the camber adjusted. It seems like the front is almost positive. But maybe that's just the way it looks.
Yes camber adjustment is on its way soon.
did you crush/cut out the rear fender lip? Or relocate the bumper tab?
Is your car a 00-01 with an ap2 front end? It's totally unrelated, I'm just curious.
na not converted, its a 05 ap2. It was actually one of the old workers at Berk Technologies.
Why do u ask?
My quarter panel isn't pushed out at all. I just crushed the rear fender lip and moved the bumper bolt. That will help out a lot of your scraping. But mine are 17x9 +45.
I was just curious because it looked like a plastic rear window. The rear window looks huge.
