Honda S2000 Honda S2000
...s2000 all motor mods needs help
Old Oct 23, 2004 | 03:52 PM
GusRock77's Avatar
Default ...s2000 all motor mods needs help
...i have a 01 s2000 and am plaining on installing a Comptech supercharger...but i also wanted to do some engine work...so far i only have
AEM cold air intake
Comptech headers
5Zigen dual fireball exhaust
...i wanted to bore out my throttle body....and install new camshafts...to my disappointment, Spoon said they no longer plan on making S2000 camshafts...now what camshafts can i go with??...and what else can i do to beef up my engine??
Old Oct 23, 2004 | 04:47 PM
PNB's Avatar
PNB
GatorNATION
Default Re: ...s2000 all motor mods needs help (GusRock77)
You should put all your questions into one post. It will make it easier for people to answer
Old Oct 24, 2004 | 08:26 PM
papa5murf's Avatar
toda has camshafts..
Old Oct 25, 2004 | 12:26 AM
WowOzYouRock's Avatar
all motor mods but you want to install SC?
<-- confused
Old Oct 25, 2004 | 05:28 AM
profpin's Avatar
Default Re: ...s2000 all motor mods needs help (Y2K_S2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2K_S2K &raquo;</TD></TR><TR><TD CLASS="quote">all motor mods but you want to install SC?
&lt;-- confused </TD></TR></TABLE>
me too??? first off, you need to know pretty much what you want to do with your setup..because, if your gonna put sc on the car, that aem you just bought was just a waste.. also the cams that you are thinking about, a waste..
Old Oct 27, 2004 | 12:26 PM
b18c1civic's Avatar
Default Re: ...s2000 all motor mods needs help (profpin)
I think hes asking about internals, in that case, other than reinforcing the engine theres not much you can do, its just about at its full capability from the factory. The Mugen s2k actually lost horsepower with all the mods that were don't to it, it dynoed at 2 hp less than factory. I would suggest investing money in the differential before any hardcore internals, the diff is the s2ks weakest link. Other than that, you can always do sleeves to strengthen and pistons to lower compression, etc.
Old Oct 29, 2004 | 08:58 AM
GusRock77's Avatar
...yes, im planning on installing a comptech supercharger...just wanted to know if there was anything else i should do to the engine to reinforce it..
Old Oct 29, 2004 | 09:14 AM
Raw's Avatar
Raw
Getting a higher lift or longer duration cam has nothing to do with reinforcing your motor not to mention it’s a horrible idea if you plan to Supercharge your car.
Maybe you should do a little more research on cars in general and on how a motor operates before spending money on "stuff that looks cool in magazines".
Old Nov 1, 2004 | 08:56 AM
CHEETAH's Avatar
use the stock camshafts, get the Toda adj cam pulleys to take out some overlap (good for forced induction), install a thicker headgasket if you're not upgrading pistons to low compression, invest in an AEM EMS ... if you upgrade pistons and rods, get at least a 9:1 compression dished piston.
Greg
Old Nov 1, 2004 | 01:10 PM
RZFD's Avatar
You shouldn't need internals if you're just going to run the bolt on Comptech kit. If anything you may want to look into a custom header and some headwork a stand alone (AEM, MoTec, ect.) wouldn't be a bad idea either.
Old Nov 3, 2004 | 08:53 AM
JSPECEX's Avatar
Default Re: ...s2000 all motor mods needs help (RZFD)
if you are going to get headwork on it make sure that you goto a good guy that has a flow bencjh becuase i have been told that those heads are pretty much tweaked to perfect. you don't want to take to much out and end up losing hp
Old Nov 3, 2004 | 10:22 AM
greenmonster's Avatar
Default Re: ...
just leave the head stock for now since the head already flows REALLY well from the factory. plus if you have your heads ported for a FI setup and you plan to go allmotor then you are at a loss. i never had done FI setups on the f22. but ive had experience on FI with B series motors. you can just focus on your bottom end then leave the head last.
Old Nov 3, 2004 | 01:24 PM
PriMaTe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by profpin &raquo;</TD></TR><TR><TD CLASS="quote">
me too??? first off, you need to know pretty much what you want to do with your setup..because, if your gonna put sc on the car, that aem you just bought was just a waste.. also the cams that you are thinking about, a waste..</TD></TR></TABLE>
yea, you need a plan
Old Nov 5, 2004 | 08:37 AM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: ... (greenmonster)
FI on an F22? I havent even seen one either. So much R&D and prototyping goes into the F20. Sorry, I'm just an '04 owner who's itching for parts. The only thing I've come upon is an AEM CAI and misc. chassis parts.
Old Nov 5, 2004 | 08:39 AM
* B A N N E D *
Default Re: ...s2000 all motor mods needs help (b18c1civic)
you're right about the diff. i've sadly witnessed one go infront of my eyes, even before the clutch did.
pulpdeem
Honda S2000
Jan 25, 2006 07:39 AM
2000Z28M6
Honda S2000
Jan 10, 2006 05:04 AM
spooniq
Dec 6, 2005 01:15 PM
turbopyitr
Oct 22, 2001 01:36 PM
